Old 06-27-2021, 06:43 AM   #1
71c10RDU
Upper shock mounts not centered......
So I've been fixing all the previous owners mistakes on my newly acquired 71 c10. One of them was some very junky blown out rear shocks mounted in the factory location when the truck has a 6" rear drop. So I ordered up some shock relocation brackets for the rear, and a set of ride tech single adjustable shocks for the front and rear. I installed the shock relocation brackets and got my new shocks bolted in when I realized something. The factory upper shock mounts are NOT centered on the frame cross member. The only reason I took notice is because I saw my rear shocks were extended different lengths as seen in the pictures. Then I noticed that one mount is closer to the frame rail on one side than the other. Does anyone know why the factory did this? Will this cause any issues? Thanks in advance!
71c10RDU is offline   Reply With Quote
Old 06-27-2021, 01:32 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Upper shock mounts not centered......
Im not sure that I see it ALL....but can you move the rears of the brackets inboard, to straighten up the line? longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-27-2021, 03:17 PM   #3
71c10RDU
Even if you moved the rear of the brackets in, they would still be different distances from the frame. This is where they are placed from the factory, the brackets bolt into the factory holes left over from the rivets. I’m just curious as to why gm did them like this.
Old 06-27-2021, 05:54 PM   #4
PGSigns
PGSigns's Avatar
I think it was done for room for the exhaust pipe.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-28-2021, 10:23 AM   #5
SCOTI
SCOTI's Avatar
Weird. I never paid much attention to their specific location but I can def see what @71c10RDU is talking about.
I'd just relocate the mount as needed to make them symmetrical or do the 'No Limit Engineering' relocation set-up.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
