Old 07-04-2021, 09:04 PM   #1
68chevy92
Question No power to cab issue. Please read
Alright so got a 1985 k-10 w/ 350. I replaced the starter in the truck and went to go turn the key over after wards, had power to dash, locks, etc. lost all power after turning key to off. Traced down the fusible link by junction box fixed it right, wrong. Kept blowing fuses. So grounding issue you would think. Checked my wiring replaced a few wires that had been melted/ just old. Replaced all fusible links with actual fuses. Got the engine to fire. It wouldn’t rev passed idle. Does have electric choke. Couldn’t figure that out. Turned the truck off now I have no power to cab and all fusible links that I found have current/ voltage behind the fuse…. I’m dumbfounded. Thought about adding a ground to the firewall if the fusible link by junction box. Any thoughts would be appreciated.
68chevy92 is offline   Reply With Quote
Old 07-04-2021, 10:29 PM   #2
Dead Parrot
Re: No power to cab issue. Please read
If the problem started after replacing the starter, I would check every wire that runs to the starter. Both for burnt insulation and also for correct connections to starter/solenoid.
Also check alternator. Possible the dying starter took the alternator with it.
Check the ignition switch and neutral safety switch at the base of the steering column inside the cab.
Dead Parrot is offline   Reply With Quote
Old 07-05-2021, 07:58 PM   #3
cadillac_al
One of your starter wires must be shorting.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-11-2021, 10:09 AM   #4
Corts60
Just here to tinker
Corts60's Avatar
Always go back to the last thing you touched when things go wrong after a part replacement. I agree with above posts. Most likely something wrong with the wires on the starter.
chevy 1985, electric issue, help me
