10-19-2021, 10:16 PM | #1 |
Original accelerator pedal firewall linkage needed
I have a 68 c10 and am in need of the gas pedal firewall linkage that you connect the rod to the 2 bbl carburator. I have the rod. The pedal was chaged to a cable system for an edelbrock 4bbl. I want to go back to the stock 2 bbl with the rod linkage. I see lot of owners who have gone to the cable system. If you kept the old linkage i would buy it from you. Thanks.
10-19-2021, 10:39 PM | #2 |
Re: Original accelerator pedal firewall linkage needed
Why not get a new bracket and keep your cable working.
But if you insist on the mechanical linkage just be aware the 6 banger and v8 linkage on the firewall are different lengths. |
Tags |
throttle linkage |
