Blazer Tank for EFI - LS3 Setup ????
Couple questions in regards to K5 LS3 build - motor is 585HP - 540FTTQ
1. I have a "newer" plastic Blazer replacement tank for the old carb setup. Is there an in-tank setup that I can just install in place of the "factory" pickup tube? a. if so what size pump is required for 585HP b. line size should be what? 1/2'' ? c. is there a returnless regulator so I can eliminate the return line? 2. Love the Boyd Welding Tank with the Aeromotive Stealth 340 Pump but becomes pretty pricey when adding all the needed options ( fuel level sensor, mounting kit) $820 + shipping.... 3. If I go with Boyd tank does the passenger side -90 degree neck work with the Blazer setup?? Its listed as C10 on the website
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
![]() Join Date: Mar 2009
Re: Blazer Tank for EFI - LS3 Setup ????
I used a Holley retrofit module for an msd atomic fi system. I would guess fuel pressure could be regulated to whatever the ls3 needs. I just drilled a second hole in my plastic tank.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
![]() Join Date: Dec 1999
You can start to see what I am doing about post 113 in my thread. I chose to use a factory pump and factory Blazer tank to modify. Maybe you could have aftermarket tank to use a factory pump IDK. Less money on the tank the way I am going, maybe more fab work. Aftermarket pumps fail, heat the fuel and are designed for constant feed or a return type system. The way I went might cost a bit more with the pwm fuel control but I think it is much more reliable. Aftermarket fuel delivery is old school with the current tech. They have invested a lot of money and do not want to give it up and the general buyers agree with them.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#4 | |
Richard - great build.... have a few questions if you don't mind. Love the idea of using GM components for ease of availability when traveling.
1. What do you mean by controller for the fuel pump? 2. Is the ZL1 a returnless system 3. Does it have built in regulator? 4. Where did you get the mounting ring?
#6 | |
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
I did have a chance to visit the VaporWorx Website - it does not answer most of the questions. Took me a while to find the ring....... wonder if there is cheaper ring option....
One main question - I have an EFI harness from PSI - is this sufficient or have the ability to operate the ZL1 pump, why is their controller needed ?
#8 | |
this is my motor setup .... https://blueprintengines.com/product...on-bpls4080ctf
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() Last edited by 6600DURAMAX; 10-20-2021 at 05:14 PM. Reason: found out |
#10 | |
Here is some of their PWM information. I thought maybe there was a write up about using the ZL1 pump? Maybe it was a different site and they linked to vaporworx for the ring. If I think of it I'll post it but the pump gets plumbed weird like a T and then a return right at the hat. I'll see if I can find it but no guarantees. https://www.vaporworx.com/pwm-contro...election-tool/
#11 | |
Some have already started answering with good info. 1. What do you mean by controller for the fuel pump? As said I am using Vaporworx for the controller. Local to me, met Carl the owner when I picked up my stuff. He is a nice guy and real smart. Pump is pwm controlled. Along with 12v it needs a separate signal to tell it how hard/fast to pump. Might be able to obtain that from some ecms. In my case using the e67 for my motor it appears to come from another module. Using the VW controller seemed like an easier route than trying to integrate bcms. The controller generates the pwm signal. You can use the fuel pressure sensor he supplies or a map signal as input to the controller, I am using the map signal. 2. Is the ZL1 a returnless system - Yes 3. Does it have built in regulator? A regulator is not needed. The pump will speed up or slow down to provide the motor the amount of fuel it needs. Other benefits- pump is not running full tilt all the time = quieter, longer life, lower amps, not warming up fuel just to name a few. Another + is the pump has its own sump. No need for a baffled tank. Was told motor would run for over 30 seconds not being submerged in fuel. 4. Where did you get the mounting ring? As mentioned, Vaporworx. They can be found cheaper. Just have to look. Wanted to add information about the comment above that "pump gets plumbed weird" You just run one fuel line from tank to fuel rail. The tee is inserted to add the pressure sensor in the line if it is used. No disrespect intended to poster.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 10-21-2021 at 01:14 AM. |
Thanks for the kudos.
#13 |
Richard - been doing some more digging into the fuel system - you mentioned taht you probably went the more expensive route but I'm not sure?? I could be missing something but here is what I came up with below
The below is using a BOYD WELDING Aluminum tank as the starting point for both systems GM MU2101 Setup - Returnless system, no regulator, no added filter 1- Boyd Tank with MU2101 flange - $650 2-MU2102 fuel pump- $215 3- Vapor Worx Controller - $429 total roughly $1,300 Aremotive Setup 1- Boyd Tank with Aremotive 340 Pump - $820 2-Aremotive Regulator - $200 3-Aremotive Fuel Filter - $110 4- Misc Fitting for all that - $50 5- Return Line - $50 Total - $1,230 What am i missing on the above?? Seems like the MU2101 isnt really that much more expensive and is probably more reliable ? thoughts
#14 |
Have checked out Tanks Inc website. I have found their prices competitive.
I wonder why you want a return less system. It is easy to use a return system by putting a 99 Corvette filter/regulator near the tank. The filter has a built in regulator and return. Last edited by cj847; 10-28-2021 at 09:19 AM. |
#15 |
The only reason from returnless was less lines, fittings ect...
Keeping all my options open at this point - very interested what other have done to create a reliable system. I'll check out Tanks Inc. today
#16 |
![]() Join Date: Jul 2015
This. This is quite easy to do, the filter is readily available at all your parts stores for low money too. Then you only need a short run of return hose. Speedway sells a complete set up for doing exactly this, or you can piece it together with parts store items pretty easily. And you should be fine with -6 feed line, half inch would be over kill i feel, especially for an N/A application.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop. 07 Silverado Classic 2wd 95 Camaro 427SBC/TH350 |
#17 |
Just talked to Blueprint engines - for this 408 - they recommend 340LPH and 60 psi
Looks like the corvette filter/regulator is only rated at 255 LPH - do they make a higher rated one or is it best to just go with Aremotive, Holley or like brands ......? Can the regulator and filter be mounted back toward the tank to limit the return line distance?
#18 | |
This is in a 68 C10 with L83 Gen 5 engine. |
#19 | |
#20 |
I mentioned above some of the benefits over this type of system. You are basically putting a heater in your fuel tank for no reason.
#21 | |
#22 |
Those Corvette set-ups (filter/regulator/return units) are mounted near the tanks (mid car) so it makes sense to replicate if used on something different.
#23 |
I've used the Corvette FFR on a number of swaps. Never had a issue. My LS6 swapped 98 Wrangler has a 255 Walbro and Corvette FFR and has been in over 14 years with zero issues.
On my 68 C10 ls swap I used a Tanks Inc 69 Camaro efi tank (Fills behind the liecene plate) and 255 Walbro. Worked well. I did a LS2 stroked to 427 cubes in a 67 Nova. 500 rwhp and used -6 lines/255 Walbro lines and it worked great. No fuel starvation issues. |
#24 | |
https://www.onallcylinders.com/2017/...m-right-video/ |
#25 | |
Unless you are running a heat exchanger (cooler) in the fuel line the fuel will continually warm up. Article actually states some positives that I said as well. A pwm fuel pump will maintain constant pressure while providing the amount of fuel the motor needs. It is more energy efficient and runs at a lower speed most of the time creating less heat. The main reason the pwm style fuel systems are not sold and adopted by the big names is loss of sales. Aftermarket does not make pwm pumps and you only need a controller, factory pump and one fuel line. If you go the standard way they can sell you a pump, regulator, more fuel line and fittings + a filter. Just trying to show there are other options.
