Brake rotor mystery
Hello,
I am sure there is something that I screwed up but I wanted other opinions. Parts and pic below. Didn’t post pic as it comes through huge from Dropbox. My brake caliper is not aligned evenly on the rotor. Front Brakes • TIMKEN 8871 seals • TIMKEN set 3 bearings • TIMKEN set 5 bearings • Powerstop AR8600 rotors • CPP d52 brackets 6087DBK • CPP modular 2 1/2” drop spindles for 73 to 87 for qa1 control arms • Wilwood D52 140-11290-R https://www.dropbox.com/s/t9q2nw0z5h...%20PM.jpg?dl=0 |
![]() Join Date: Mar 2014
Re: Brake rotor mystery
I think you spindles may not be designed to work with the standard D52 calipers you have listed. If you check the Willwood site and put in the info for a C10 with CPP spindles the only options listed are the 6 piston calipers designed for 13-14" rotors. You should probably call CPP for more info. What is the part number of your drop spindles?
https://www.wilwood.com/BrakeKits/Br...2+Drop+Spindle
Made in America by Americans |
#3 | |
My thought is the d52 should work with the brackets. |
Problem solved. Was shipped the wrong calipers.
