12-01-2021, 09:54 PM | #1 |
Rear view mirror glue.
To top off a wonderful couple of weeks today my rear view mirror fell off when I closed my trucks door.
When I put it on I scraped the windshield plus sanded down the area with 80 grit to get a good bite. Plus cleaned up the metal tab, and put small slots in it for extra hold. When I saw it today It had a run coming from the spot where it once resided. I bought the glue from autozone, and mixed per instructions. Any thoughts on why it failed now? |
12-01-2021, 10:17 PM | #2 |
Re: Rear view mirror glue.
I tried 3 different brands and had no luck. Went to a local Glass guy and they glued it on for $20. I had spent that on adhesives.
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
12-01-2021, 10:51 PM | #3 |
There are a lot of 72 model years running around with 71 and earlier screw mounted mirrors because of that same problem, especially 4WD's. Heat generated from the summer sun doesn't help either.
Doesn't answer your question but that's how I solved my issue where the glue wouldn't hold. |
12-01-2021, 11:35 PM | #4 |
I went to a windshield place with a later model truck and they glued the little tab on for nothing. Took the guy about 1.734 minutes. I offered to pay and they said no.
12-01-2021, 11:49 PM | #5 |
The Loctite professional glue glass shops use is far superior to anything you can buy in an auto parts store. I'd recommend stopping by your local glass shop. I always glued mirror tabs on for free.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-02-2021, 01:15 AM | #6 |
I've had the same issue with my 95 Dakota. I tried at least 4 different times and it's fallen off every time. Took me well over a year before I tried again. I used the 3m kit in the red and black package that you can get at the parts store. I made sure to clean both the glass and the metal button really, really well, then followed the instructions to the T. Also did it in a shady spot when the weather was moderate. So far, it hasn't fallen off yet, but it's only been a couple months and I haven't touched the mirror to adjust it since the adjustment after gluing it back on.
If it falls off again, I'm going to a glass shop next
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
12-02-2021, 02:15 AM | #7 | |
Mine keeps falling back off, but it's a van so the mirror is useless anyways.
12-02-2021, 09:51 AM | #8 |
This is where too much is no good. Most people put to much on the button but a tiny little drop is best .
12-02-2021, 01:52 PM | #9 |
Same deal here, I even tried the Gorilla super glue the second time. That lasted a couple of weeks then fell again.
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" '06 3500 Duramax ...tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
12-02-2021, 05:17 PM | #10 |
I used Permatex brand and so far so good. It has lasted about 4 months. I still gingerly handle the mirror when moving it though. I put on a mirror that has the compass and temperature display from a Saturn Vue so it does have a little more weight then standard mirror. My truck sits in the sun all day long and I slam my doors to shut doors due to newer seals. The permatex comes with a little towelette that has some kind of cleaner or activator and that seemed to work.
79 Chevy 2wd BIG10 350 TH400 |
12-02-2021, 05:39 PM | #11 | |
12-03-2021, 12:48 AM | #12 |
I think the square body headliner goes all the way to the windshield, not sure exactly where it stops but I think the headliner tucks into or at least to the windshield rubber. Maybe someone in the know will chime in.
12-03-2021, 02:20 AM | #13 |
Seriously, stop by a glass shop. It will take you 10 minutes and you'll never have to worry about it again.
12-03-2021, 03:01 PM | #14 | |
I don't worry about it. I have two other mirrors.
12-03-2021, 03:05 PM | #15 |
i gave up doing these at work my local glass shop will gule them on for 17 dollars and give a life time warranty
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-03-2021, 03:28 PM | #16 |
Same here. Glued it twice. Second time lasted years until I banged my head on it putting in a new dash. It took out a giant chunk of glass too. Went to a glass shop and they did it for $10.00.
12-03-2021, 11:52 PM | #17 |
Mine just fell out of my 87. I need to take it to the glass shop. Might do that in the morning.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
