01-03-2022, 08:39 PM | #1 |
laying low
heavy power steering
It's been a long time since I had my 88 pkup so my memory is a bit fuzzy on some particulars.
My low mileage (82,000) 91 sportside's steering takes a bit more effort than my newer trucks, especially when just backing up and turning at near idle speed. Was that normal back then? The pump is quiet with no leaks and all the steering components are tight and it has stock rims and tires. Wonder if new ps fluid would make a difference.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-03-2022, 10:11 PM | #2 | |
Re: heavy power steering
Sounds like the pump is weak. Mine was hard to steer at low RPMs until I changed the pump.
01-03-2022, 11:19 PM | #3 |
laying low
I have seen where some guys put a shim in the pump outlet pressure valve to up the pressure. Ever tried that?
01-03-2022, 11:51 PM | #4 | |
No. I used a pump I had lying around that came from a Cadillac.
01-04-2022, 12:06 AM | #5 |
laying low
I have heard there are different pump pressure valves to tailor the pressure to different applications like Camaro, Vettes, full size cars, 3/4 & 1 ton trucks. So far I don't find those valves listed separately at O'Reillys.
01-04-2022, 01:38 AM | #6 | |
The Cadillac and truck valve both looked the same to me. I used the truck valve. Pretty sure a new pump comes with one. I don't see why you would want to switch the valve on a bad pump.
01-04-2022, 02:43 AM | #7 |
laying low
I'm not convinced just yet the pump is bad. Normally one will whine or growl when it's failing. This one is still quiet.
I'm exploring options is all. I've got another truck with a quick ratio sector that I think could use a little more fluid pressure. I thank ya.
01-04-2022, 08:34 AM | #8 | |
My pump sounded normal too, but it wasn't.
01-04-2022, 10:24 AM | #9 |
My 91 C1500 I always felt had "heavy" steering but I think it was just normal. It had no pump noises and was a fairly low mileage truck when I had it. My current 93 K2500 Suburban actually feels a tad bit lighter when steering even though it's certainly heavier up front being 4wd with a 454.
Dave R. 1972 K20 1972 C20 Highlander 1957 Chevy 210 Delray 1967 C10 |
01-04-2022, 11:24 AM | #10 |
laying low
Hi Dave. I am thinking that "heavy" feeling is mostly normal for those early gmt400 trucks but looking for confirmation I guess. Just how heavy was normal? I have just forgotten how my 88 drove.
In comparison, my 06 and 09 GMCs outdrive the 91 by far. The 91 only has 82,000 actual miles. Something in the design changed in the mid 90s. My 97 had an easier steering feel as though the ratio had changed maybe. So I wonder if the steering sectors from late 90s easily interchange with the early 90s. Probably so. I may explore that.
01-04-2022, 03:04 PM | #11 |
I haven't noticed a heavy feeling in my '90 k1500, but I can't compare to anything newer than my '93 toy, I just don't drive newer vehicles. I recently had an issue with the toy where the steering fluid was getting low, but no leaks. It turns out it was getting sucked into the intake. There is a pressure switch that when the power steering starts to work, the fluid pressure change opens a valve. The valve introduces a vacuum leak causing the engine to rev up a few rpm, providing more power for steering. The switch was later changed to electronic. I don't know if our Chevy trucks have a similar system? If so, and if it wasn't working, that could cause a heavy feeling in the steering...
'47 Panel to '88 K2500 Frame Swap Mechanical Speedometer Drive Solution 1947.2 1 ton Chevy Panel 1955.2 Chevy 6700 Bus/RV 1990 Chevy K1500 |
01-04-2022, 03:06 PM | #12 | |
I have a used box that I still need to put on, but I was only changing it because my pitman arm shaft is worn. I do remember asking the interchange and the newer boxes are different in some way. My 99 does steer way better than the 93, but the 99 also has a different pump.
01-04-2022, 03:52 PM | #13 |
A lot of the 99 and newer use rack & pinon versus the worm gear style steering. I know some of the HD models and maybe 4x4 models still used the worm-gear style. Just never figured out what made the difference. I loved the rack & pinon on my 02, 05, and 07 models. If you have been driving newer models or pre87 models, the 88-98 years will seem to have a bit heavier steering.
01-04-2022, 05:39 PM | #14 |
laying low
I have ran across numerous old threads regarding heavy steering issues on the 88 and up pickups. Some stated their truck drove that way from new. It's way different than the preceding 73-87 trucks steered. Most thought it was a faulty steering sector and some replaced theirs with the Red Top or AGR brands. A couple mention replacing the pump. Some never posted the solution, if they found one, to their truck's steering issue.
My 97 2wd pkup and 97 4wd Suburban both had that speed sensitive steering assist or something like that. It had a switch in the pump and a sensor around the column inside the truck. They were problematic and the part on the column would fail making the steering intermittently twitchy while driving around curves. For a millisecond it felt like the steering wheel was no longer attached to the steering linkage. It was unnerving when it acted up. Makes a fella's heart speed up a bit! It would boost the steering assist while you were in a turn for a split second. I replaced a couple of them and I unplugged one and drove it for months without the sensor assist and it drove just fine. Anyway those 97 models were easy to drive with a balanced feel. I don't know how many years GM used that sss assist system but most of us don't miss it.
01-07-2022, 03:07 PM | #15 |
My vote is on the PS pump. I had to replace one in another truck of mine. They do go bad without any other fault detected like a noise or leak.
1989 K1500 Chev. EC Original owner; some of the aftermarket parts I've installed are Borla headers, Hypertech chip, Edelbrock water pump, and a Stillen rear disc brake conversion kit. 2009 Hummer H3T 3.7L 5M (sold) 1997 K2500 Chev. EC 7.4L/ 4L80E 2018 Dodge Ram 2500 HD R/C |
01-14-2022, 10:36 AM | #16 |
in 88 they put a bigger torsion bar in the steering box, which made them steer harder. you can swap the input from a 80's truck box and it will steer easier.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
