Vintage 4x4s
Visor Rust
Hi all, I'm wondering if the rust above the windshield is pretty common on these? I assume its a challenge to fix, like it is on the pickups?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Visor Rust
Hi Jud. Rust in the windshield frame is relatively common. Some reproduction pieces are now available to help with this sort of repair.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Visor Rust
Mine had it. Bubbles and holes on the inside above windshield. GMC Pauls carries the replacement metal.
Chad |
#4 | |
Vintage 4x4s
Re: Visor Rust
Thanks for the info, Chad
![]() Join Date: Dec 2002
Re: Visor Rust
If you search there is a post where member takes you through the process.
Pieces needed adjustments to work. |
