01-21-2022, 07:44 PM | #1 |
Engine is hard to start and idles poorly at 1/4 tank reading
Hope someone may have a reason on this. When fuel gauge is showing 1/4 tank or less, Blazer become stubborn to start and idles poorly. I currently don't have truck to look at.
Mechanic who did brake, suspension and some mechanical repair commented on this, and put more fuel in. When I first brought it home, there was around 1/2 tanks and started easily etc. As we ran fuel down while testing things including temperature gauge replacement, once fuel gauge got to around 1/4 it again became hard to start. I think put around 10 gallons in to Blazer for my trip to body shop, and it again started easily on all occasions. After the drive it was down to showing 1/4 tank, but driving normally. As soon as I pulled up, put trans in park it stalled, like out of fuel. Fuel gauge could be out, but seemed to operate perfectly on trip, original mechanic had put some fuel in it and was still acting poorly. Put new fuel pump on but situation remained, put more fuel in, problem gone. The truck does have the remnants of an auxiliary tank, so fuel lines are a bit of a mess. This is planned to be fixed. Any other thoughts on this, why fuel feed would diminish when tank gets low? |
01-21-2022, 09:03 PM | #2 |
Re: Engine is hard to start and idles poorly at 1/4 tank reading
Maybe the sending unit is off a bit and when it reads a quarter it’s really empty.
Jeremy 1969 Blazer 4x4 original cst 1971 Blazer partial 2wd convert 1972 Blazer 4x4 original cst 1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper 1970 4x4 suburban w/ 6in lift and 35in tires 1968 Corvette convertible 1970 Malibu convertible 1959 Brookwood wagon 1972 International Scout ii |
01-21-2022, 09:21 PM | #3 | |
We could get it to start at low level, just took multiple attempts. I'm wondering if the venting canister maybe an issue? |
01-22-2022, 10:56 AM | #4 |
I had a Japanese beetle floating in my tank, it would shut off fuel when it was low, took me forever to find the problem. I would start by looking for the problem by checking flow at fuel pump inlet and then go backwards to the tank, maybe blow out lines with about 5 psi of air
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
01-22-2022, 06:14 PM | #5 | |
I'll check tank for any insects too |
01-25-2022, 09:41 PM | #6 |
Sounds basic but maybe fill the tank, let it run down till the symptom happens. Fill it back up and see how many gallons that takes as compared to factory capacity. See if it’s really a 1/4?
Seems the sending unit arm could be bent. You could have some sludge in the bottom that more fuel dilutes and it only becomes an issue with less fuel? Just random thoughts. Good luck with it |
01-25-2022, 10:39 PM | #7 | |
01-28-2022, 12:04 PM | #8 |
When I had a truck with dual tanks the selector valve was messed up.my truck would run out of fuel. It seams that it would send the return fuel to the 2nd tank. Water in fuel? Methanol fuel loves to attract water. Fuel gauge off? Maybe a rust hole in the pickup tube?
01-28-2022, 01:39 PM | #9 | |
Thinking maybe I should have blocked the old feed line, getting air? |
01-28-2022, 03:07 PM | #10 |
When I had that problem, I was on the side of the road and just bypast the valve completely. It stayed that way for the rest of the time that I owed it.
