![]() Join Date: Jun 2019
Square body k20 front axle
What front axle came in a square body k20 .I found a square body k20 not sure what year it is park in a building with boxes around it and on it but it does have a 14 bolt rearend thank u for any help
Post Whore
![]() ![]() Join Date: May 2015
Re: Square body k20 front axle
Depending on yr...Corp 10bolt or Dana44..
Got a pic?..the Corp 10bolt has little ears on the chunk housing Itll be the same axle as a k10 has , except k10 has 6lug outers
No pic to much junk around the front and sides of truck when did they stop putting dana 44 in them
All about them K’s
![]() Join Date: Jun 2014
They were spotty and intermingled with the 10 bolt from ‘77ish all the way to about ‘80. Around ‘81 or so and the 44 was done.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
Post Whore
Yep k30 for the d60,
Thank u is the 14 bolt rearend and the front axle worth anything
Post Whore
Is the 14b and semi or full float?..
Either way, yep, they are worth something, I recently bought a K20 10b corp front and 14b semifloat rear, gave 500 for both axles and a set of stock tires and wheels
I can only see the truck from the back of it the truck is rough but there the bed is gone
That's good to know because I have a set (4:10) from my 85K20 I need to get rid of after the CUCV swap.
