Old 01-28-2022, 03:01 PM   #1
GMC71k20
steel wheel offset
Did the factory steel wheels have different offsets between the front and rear?
GMC71k20 is offline   Reply With Quote
Old 01-28-2022, 04:03 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: steel wheel offset
Not that I’m aware of. Are you having issues of some sort?
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 01-28-2022, 04:23 PM   #3
GMC71k20
I am trying to piece together a set and I bought some mid 70s gm
Van wheels without noticing the difference in offset
Someone local to me said they had different offsets in the front and back
But I thought that was wrong since the front ends have a wider track
The top picture is the van wheel - this has about .5 less offset
The bottom picture is an original wheel
Old 01-31-2022, 12:14 PM   #4
duallyjams
duallyjams's Avatar
The only time I have seen a difference in back spacing is in different size diameter rims, 16" verses 16.5" and 17", 17.5"
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 02-02-2022, 12:41 AM   #5
Short 3/4
Not sure if you are working with a drum or disc 3/4 ton, but if its drum, be very careful of clearance caused by offset, or rivets vs welded. Some cause very slight distortion of the drum that causes endless headaches and eventually ruins very hard to get drums (ask me how I know).
Hope this helps
Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 4.10 rear
Short 3/4 is offline   Reply With Quote
Old 02-07-2022, 06:53 PM   #6
LONGHAIR
They are the same within the same vehicle, as in front to rear. They would "have to be" to do the typical X shape tire rotation.
However vans are different from trucks, they are usually narrower too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 02-09-2022, 10:38 AM   #7
Vans came with flatter wheels, more backspace. Same with the 5-lug van rallye wheels being 7"
