Old 02-11-2022, 12:40 AM   #1
72gmcdiaz
Which generation easiest to swap?
Which generation (47-54 55-59 60-66 67-72) of truck is easiest to swap in a 12v cummins without need to cut firewall?
in other words, which of these trucks have more engine bay space?
Ive seen many threads but some have cut firewalls some don't.
Im thinking of getting a 1 ton truck of any generation of these to swap in a 6bt nv4500 and use it as a tow rig
72gmcdiaz is offline   Reply With Quote
Old 02-12-2022, 11:38 AM   #2
Ziegelsteinfaust
Re: Which generation easiest to swap?
I have not done one, but I have dreamt of doing one.
The 60-72 years are the easiest, but still cutting the firewall is a typical option people follow. Or they move the radiator in front of the core support, and it gets crowded. Myself I would remove the cab, and set the engine where I want. Then lower the cab, and start the surgery.
The earlier trucks are narrower cabs. And yes people.have done it too. But real-estate aka foot room gets a bit tight. So alot of people do 4 cylinder swaps on those among the reasons.
The 6bt is a big girl, and luckily plenty of people have done it. So find the formula you like, and copy + paste. The reason some cut and some don't basically is. Either way you go you get a set of problems to deal with. Cutting the cab solves oil pan cross member issues. Moving the engine forward solves firewall issues. The reason I would cut the firewall is so some of the engine's mass is shifted to the rear for a better handling experience.
Damned if you do. Damned if you don't.
Finnegans garage did a swap on the ramp truck which is a pretty good brochure on them. Plus there has to be several in depth swaps on YouTube besides forums.
Ziegelsteinfaust is offline   Reply With Quote
Old 02-19-2022, 12:22 AM   #3
Dewey72
Did mine on a 72 short box 6bt nv4500 swap and didn’t have to cut the fire wall or move the radiator to the other side. I used a Autoworldmt crossmeber and it worked nice. Mine was a 4x4 so I put a 4” lift on it to help with the front axle clearance and put a 1” body lift just to help clearance issues but probably not needed. Not sure on the other years.
Dewey72 is offline   Reply With Quote
Old 02-24-2022, 08:32 AM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I've done a lot of 69 up swaps and never cut one firewall. I have rolled the floor to firewall seam to clear exhaust or make trans removal easier. I cringed when they cut the ramp truck's firewall. It didn't need done. But hey, it's not my truck.
The 50s and 40s trucks are definitely harder to swap and for sure will need firewall work to get them in there.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-01-2022, 03:07 PM   #5
rickcdewitt
rickcdewitt's Avatar
Man a 55-59 long fleet bed 1 ton with a cummins would be so sweet.4x4 would be even cooler. Not a small engine bay on those trucks?
1970 k20 6.0l/nv4500/np205/14bff in progress
build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014
rickcdewitt is offline   Reply With Quote
cummins 12v 1 ton
