Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 02-14-2022, 02:29 PM   #1
Kateye_Kenzie
Decoding rear differential casting number
Jumping on this old thread... I'm currently trying to figure out what differential is in this 1974 GMC C6000 truck we're working on so I can get a new differential for it. The VIN is TCE624V556692 and the casting number is 987355. I've talked to just about everyone locally I can find and I'm losing sleep at night over this! If I can get ANY directives from someone who would have half an idea of what might be in this truck I would appreciate it! Thank you!
Kateye_Kenzie is offline   Reply With Quote
Old 02-14-2022, 04:22 PM   #2
BigBird05
Re: Rear Differential Casting Number -- How to Decode??
Casting # don't mean much. On the RH axle tube, either on the front or on the bottom will be a stamp letters and numbers. Those will give more info as to year and gear ratio as originally made. Post those and maybe we can help.
BigBird05 is offline   Reply With Quote
Old 02-14-2022, 05:15 PM   #3
Kateye_Kenzie
Just spoke with the boss... there are none of those numbers on the axle and that's why he only gave me the casting number... And the pinion is broke out of it and missing so I can't rely on that either. Does anyone know what was in these trucks out of factory? I'm talking to the GM Heritage Center right now but they take weeks to reply...
Old 02-15-2022, 10:56 PM   #4
C10 - C90 Bill
C10 - C90 Bill's Avatar
Re: Decoding rear differential casting number
Check out the info on the SPID.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 02-17-2022, 02:48 AM   #5
Bob B.
Yes, check the SPID label, should be in the glove box. Problem is these trucks were available with many rear axles, GM, Eaton, Spicer, ect.. Good news is most medium truck axles were common and used in many makes of trucks, so parts availablilty is usually not a problem.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 02-17-2022, 10:14 AM   #6
Kateye_Kenzie
I feel kind of ridiculous asking but what's the SPID label? How would I read something like that? What does it look like? And why have I never heard of it before?
2004 Chevrolet Silverado 2500 LB7 Duramax 6.6L
2004 GMC Sierra 2500 LB7 Duramax 6.6L
1985 Chevy Camaro Z28
1970 Chevy Vega Panel Wagon
1956 Chevy Bel-Air 4-Door
Old 02-17-2022, 10:19 AM   #7
C10 - C90 Bill
SPID is short for Service Parts Identification.
It's a label that tells the info on your truck when it was built. I didn't indicate where it would be on a '74, as my knowledge pretty much stops at '72. But like Bob has indicated check the inside of your Glove Box Door. They can be a little hard to decipher, but look for the info for the rear. If necessary, try to post a picture of it. Hopefully it is still there.
GMC 9500 Fan
Detroit Diesel Fan
Old 02-17-2022, 10:19 AM   #8
C10 - C90 Bill
Double post
GMC 9500 Fan
Detroit Diesel Fan
Old 02-17-2022, 02:21 PM   #9
Pick121
Pick121's Avatar
Hello, not to challenge “the Boss” but, the rear axle stamp numbers are different from the casting numbers, are easy to miss if covered in road dirt & grime. They may be on the axle tube itself. Might find them with a closer look, wire brush/degreaser. See attached photo for example. It is possible they might not be on the axle, or unreadable, but if he can find them it will be way easier to determine the rearend
Pick121 is offline   Reply With Quote
Old 02-18-2022, 10:06 AM   #10
Kateye_Kenzie
I've also thought of that and the problem with that method is that..... those numbers are nonexistent! They're nowhere to be found, which is why I'm struggling so darn hard. Thank you, however.
