03-14-2022, 07:38 PM | #1 |
1967 wiring harness
looking for a stock, uncut and unmolested complete wiring harness AND fuse block. I'm working on a 67 2wd v8 with a 3 speed and my fuse block is totally rusted out. I understand that other year wiring will work, however I'm trying to keep it simple.
Thanks |
03-14-2022, 11:38 PM | #2 |
Re: 1967 wiring harness
Have the fuse block from a 67 GMC with the full seven hole gauge panel, the harness is pretty ragged and chewed. If have an interest in the fuse block let me know and I can take a look at it for condition. Should be able to come up with 6-7 inches of pig tail wires on it for splicing.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
03-15-2022, 05:58 PM | #3 |
Looked at the 67 fuse block I have and it has nice clean fuse location printing but does have rust on the fuse clips. Maybe could be cleaned using a small dremel tool wire wheel, not sure there. Let me know if you have any further interest.
03-16-2022, 01:31 PM | #4 |
I'm interested. Pics of fuse box would help. I can make the 6''-7'' pigtail work if that's the engine bay wiring. Working with someone else on a wiring harness he has. Hopefully between the 2 of you I can get what I need.
Thanks |
03-16-2022, 08:33 PM | #5 |
Still in the truck hooked to the wire harness which is rather hacked up here and there. Will get a couple pics taken tomorrow and post them. Hopefully will show what you need and your looking for.
03-17-2022, 10:45 AM | #6 |
I have a complete 67 C10 harness, for the whole truck.
removed carefully, no wires cut. in the box ready to ship. Let me know, if interested. Thanks, C101968 |
03-17-2022, 01:06 PM | #7 |
i have a 67 engine harness for a c10, that i have modified to hun HEI and internally regulated alternator with electricric choke and Tach. and a headlamp relay
All the harness has been lengthened to hide the wirng in the passenger fender I install breathalyzers for a living so i have the means to modify the harness correctly and crimped and soldered all new joints 80.00 plus ship
1967custom |
03-17-2022, 05:17 PM | #8 |
Looks like you have a few options but as mentioned here are pics of the fuse block I have. Still in the truck, can cut at most any length needed for splicing. Nice clear lettering, does have some scale on the fuse clips. $22 shipped, money order or $$, do not have Paypal.
03-18-2022, 03:04 PM | #9 |
Ironhorse........thanks for pics. A little to far gone for me.
michael bustamante- thanks but a little to fancy for me. I'd like a stock one. C101968- message sent. |
03-18-2022, 06:49 PM | #10 |
67sss, understand, it is a bit rough but good clear legible printing. Too bad the fuse clips have the rust scale as they do. Good luck in your search.
04-04-2022, 05:08 PM | #11 |
found one. Thanks for all that replied.
