Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WTB Parts
Old 03-19-2022, 02:59 PM   #1
paul mora
WTB 2 bbl carburetor
I need a good ready to install 2 barrel carburetor for my 6 cylinder GMC.
Pulatoy
paul mora is online now   Reply With Quote
Old 03-19-2022, 03:26 PM   #2
geezer#99
geezer#99's Avatar
Re: WTB 2 bbl carburetor
I think you need to narrow it down!
Are you looking for a Rochester 2g, stromberg, varajet, dual jet or something else.
Which 6 cylinder helps too.
geezer#99 is online now   Reply With Quote
Old 03-19-2022, 03:32 PM   #3
paul mora
Rochester
Pulatoy
Old 03-19-2022, 03:42 PM   #4
geezer#99
geezer#99's Avatar
That’s a 1 barrel mono jet.
Do you have an adaptor or other intake.
Old 03-19-2022, 05:16 PM   #5
paul mora
What you see is on the truck and is not working Then rebuilder is 6 weeks behind and I thought I would check here to see if anyone has one they do not need. Next option is tho go to Classic Industries and see if they one on the shelf
Pulatoy
Old 03-19-2022, 06:13 PM   #6
geezer#99
geezer#99's Avatar
Used ones here.
https://www.12bolt.com/store/c47/Roc...ojet_Used.html
Old 03-20-2022, 01:05 AM   #7
Hidesertchevy
Try carb shop. Ontario California
Hidesertchevy is offline   Reply With Quote
Old 03-20-2022, 02:31 AM   #8
franken
Rebuilding a Monojet is pretty simple and is probably less work than an adapter and headaches of the conversion. Rebuilding a 2-jet is pretty much the same.
A can of B12 and a carb kit isn't expensive.
franken is offline   Reply With Quote
