Old 03-28-2022, 07:21 PM   #1
blazerowner71
Axle length
I was putting tire on my 71 Blazer and noticed that the front tires were sticking out farther than the back so i measured the distance between the tires the front was 581/4 the back was 56 inches is this normal or did one of the axles get replaced and which one? Any help would be appreciated.
blazerowner71 is offline   Reply With Quote
Old 03-28-2022, 08:13 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: Axle length
Nope that’s factory. Pretty much all GM K’s have the front track width wider than the rear.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
57taskforce is offline   Reply With Quote
Old 03-28-2022, 09:49 PM   #3
blazerowner71
Re: Axle length
Thank you for the help
Old 03-29-2022, 08:42 AM   #4
Re: Axle length
Yep, you'll get people driving behind you telling you your truck is crabbing because they can only see one side
