Old 03-31-2022, 01:55 PM   #1
Sirpsych0
Body swap
I am having a hard time finding a good k10/k20 roller to start a project on. I can get my hands on an old 89 K5 blazer with a blown engine. My question, Can I scrap the 89 body, and slap a 70-72 C-10 short bed body on on the 89 frame? The 89 frame is about 4 inches shorter than a 72 K10.
Has anyone done something like this? I would think IF I got some 72 cab and bed mounts put on the K5 frame it may work.
Sirpsych0 is offline   Reply With Quote
Old 04-01-2022, 07:26 AM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: body swap
You would have to cut down the bed to get the wheel wells to match up and then IMO it would look goofy with such a short bed and not being a Blazer. Just my thoughts.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 04-01-2022, 07:11 PM   #3
Sirpsych0
Re: body swap
Agreed, that would not look good.
I found some other threads and links to people using other frames. Looks like I just need to be patient and find the right starter truck with the correct frame and cab.
Old 04-01-2022, 07:17 PM   #4
Dieselwrencher
Re: body swap
You could always cut down a burb or long bed frame. But I agree, the correct frame would be nice if you don't have the stuff to do the frame mods.
Ryan
Old 04-02-2022, 10:21 PM   #5
Sirpsych0
Re: body swap
I'd actually be happy to find a good k10 longbed frame and keep it long. The 4wd frames are just scarce in my area. Do you know if the Suburban frame is the same as a longbed? Never even thought about that.
And you are correct, I am not set up to do frame modifications. No welder at the moment and pretty tight on garage space.
Old 04-03-2022, 12:41 PM   #6
Dieselwrencher
Re: body swap
If I remember correctly, the burb frame is shorter than a standard cab long bed.
Ryan
