Headliner Yes or No
I have built a highly optioned 70 swb 2wd truck and was wandering if I should go ahead and put the factory headliner in it. My interior is already in and complete. Should I or shouldn’t I go through the trouble of installing? If I do I will not cut out for the clip in the trim only drill for the 4 corner screws. Will this hold?
Thanks Posted via Mobile Device |
Re: Headliner Yes or No
I did it that way in my last truck but I added 4 more screws and carefully counter sunk them so they looked like the other ones. I was told the clips allow the mouldings to move and not crack . I never had the truck long so I don't know if adding the screws made it easier for them to Crack. It worked but in my build I'm doing now I added the holes for the clips. It stays up tighter with the clips.
![]() Join Date: Mar 2015
It will make the interior quieter if you install one.
Thanks for the replies I just don’t want to ruin the current paint that’s on it now
![]() Join Date: Dec 2009
If you drill for holes, I would use a short twist drill.
![]() So it does not hit the top roof when the twist drill breaks thru. ![]() A Jobbers drill is already short or you could cut one off and resharpen it. Also, another option is a drill stop. Hope this helps. ![]()
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I always thought the headliner when done correctly (like original) brought a lot of class and style to the otherwise pedestrian roof. It's a great finishing piece that I only see on maybe 20% or less at shows and around town.
I like the headliners a lot. I always look at interiors to see if they have one, but they are few and far apart. I think it would look great.
I installed mine with out the trim using Velcro. My cab has all the original sheet metal and I didn't want to drill any extra holes. The head liner does help with the acoustics for better stereo sounds.
Who Changed This?
![]() Join Date: Jan 2013
CST got you the headliner, among other parts. I took mine out because my FiL had put a zillion holes in it for various JC Whitney gewgaws. Haven't gotten around to getting a new one, yet.
could you just glue the headliner instead of using screws?
Who Changed This?
I'm not sure it would hold. Mine was glued as well as having the trim on the edges holding it up.
I have glued mine up with no trim, using 3M windshield urethane. Used the same stuff to do all my side and tailgate trim. Works great and holds
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear |
#13 |
thanks for the answer, Larry
#14 |
![]() Join Date: Jan 2009
So, taking what you did one step further. You could also glue the trim around the headliner, so you would not have to drill any holes at all. That is what I'm going to do when it comes time to install mine.
#15 | |
![]() Join Date: Apr 2021
#16 |
![]() Join Date: Nov 2013
My buddy and next door neighbor does upholstery work, when my '67 is ready for interior he will build the headliner from special PVC sheet that is used for upholstery in boats.
I made him a tool that puts a counter bore for the small high strength magnets, glue them into the PVC and they hold very well to the sheet metal.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
#17 |
In my latest build i took the original headliner roof panel out and installed it in my cab but i also made a fiberglass mould from it and can be used to make holes I another roof properly.
#18 | ||
![]() Quote:
![]() Your post was the one that (Got me Brave enough) to spot drill the roof off my truck ![]() ![]()
#19 |
Would those of you who have roof liners mind posting pics? I am going to install a roof liner but want to see how they look and is the install just in the center of the roof?
Thanks!
Steve ___________________________________ http://67-72chevytrucks.com/vboard/s...d.php?t=618848 |
#20 |
This is all I have until it's all buttoned up in the truck. Will be painted red when finished.
#21 |
We used 3M Industrial double sided tape and glued the headliner in place without the trim. This stuff is super strong and will hold the headliner much better than trim screws.
When using the tape be careful positioning it to the roof because once you touch it to the surface it will stick. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
