Paint question/door panels
Is there a code for the black on the metal door panels? I am debating on going back black or color matching to the door.....yet to decide.
Scott |
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: Paint question/door panels
The code for 1970 can be found HERE and I suspect it's the same for other years.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#3 | |
For interior colors, the sheen is the most important. If you paint those door panels with a high gloss black it won't look right and you will scuff it anytime you get into the truck. You want a satin or semi-gloss (not flat) This is the best product I've found for satin a black finish. Been using it over 30 years and always had excellent results. You can buy it in quart cans as well as spray cans, but for a large piece like a door panel I wouldn't use the spray cans. It's also excellent for engine components because it gives the parts a factory looking finish. https://www.3m.com/3M/en_US/p/d/b40072367/ |
