So I bought a 75 that has a 89-91 front clip (not entirely sure what exact year). I want to get this looking as original as possible, with the round headlights. I read that the only way is to swap the whole clip 6bit given the mods already made by the previous owner to get a later model clip on it, I'm looking for other solutions.
Is there *any* other way of getting round headlights (and bonus points for older grill style) onto this truck? Is there a year that I can source headlights from and do some less extreme fab/mod work to get the result? Cheers Alex |
![]() Join Date: Dec 2009
Re: Question about round headlights on a 1990 front clip
The front end swap would be the easier task.
What did they do for hood hinges?
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
They put in some 87s by the looks, welded in. Terrible is I live in NZ so the clips are hard to come by...
It will be a complete fabrication project. There's no factory parts that will let you put round headlights in a 81-88 or 89-91 radiator support and grille.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
Don't know of an easy way to do it but a 4000(5.25") series halogen/LED round headlight bulb might be an easier fab job then the later 6012/6014(7") series.
The 4000 series were often done as a 4 bulb set, 2 with low/high and 2 with high only. If you know someone with a 3D printer, they might be able to make a cover plate for your fab job. |
Moderator
![]() Join Date: Oct 2008
The 81-91 grille is flatter across the front.
The centre section of the nose protruded past the headlamps on the 73-80
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Tags |
1975 c10, front clip, headlights |
