07-04-2022, 04:56 PM | #1 |
Drivers side kick panel vent door
Ok everyone, what am I missing here? I took my trucks vent doors apart and put in new seals. Normally I do a better job taking pictures of things before I take them apart but it seems I failed on that this time. This one seems to open too far not shut all the way. The passenger side works properly. This is definitely the door that came from the driver side, but from searching the board this door doesn’t seem to look like other driver side doors I have seen.
Did a previous owner replace the door with the wrong one? Am I doing something wrong with installation? Last edited by indymachinist; 07-04-2022 at 10:21 PM. |
07-04-2022, 05:12 PM | #2 |
Re: Drivers side kick panel vent door
I'm going to say the bracket closest to the pull knob needs to be closer to the vent door. Maybe it's been screwed down in the wrong place.
OR, I'm not familiar with that style of pull knob. Is the forward tip of the knob supposed to stop at the bracket (like shown in your pic) or "pop" up and over the curved portion of the bracket? Can the knob be rotated back so that the leading edge can push past the curve in the bracket?
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
07-04-2022, 10:26 PM | #3 | |
The pull knob is not actually stopping the rod from going any further, there are some factory squished in detent type things in the side of the rod that don’t let it go through the bracket. I could probably sand those off smooth so it could go a little further too. I was just wondering mainly if the door I have is actually the door that belongs on the driver side. From a forum search I stumbled across a couple pictures that made it look like the rod mount point on the door itself should be in a different spot on the driver side. |
07-04-2022, 11:51 PM | #4 |
Here are a couple pics of my '69. This mechanism has never been removed.
Jim |
07-05-2022, 08:49 AM | #5 |
Everything seems to look correct in the photos. The only thing that would make it not close all the way and open too far would be if the rod is too short. Double check the long, straight section and make sure it does not have a bow in it. That would make it shorter and cause the issue you are seeing.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
07-05-2022, 09:14 AM | #6 |
Post Whore
It's tough to see the problem.
Can you post pictures of the passenger side? Try to have them composed the same. Maybe we will see something then.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
