Old 07-07-2022, 08:18 PM   #1
beanious
Dirt Every Day Episode 132 (K5 Blazer Rescue) OMG...
Anyone else out there see the latest Motor Trend Dirt Every Day episode?
Long story short two guys who host an off road couldn't get a small block chevy motor to run in 3+ days.
I can't be the only one who was like:
*Number one cylinder wasn't firing
*Distributor probably 180 out
*Ya didnt't replace the wires...
For goodness sake, the episode was filmed at Summit Racing in Nevada.
They could buy the entire drive train and replace same day!
beanious is offline   Reply With Quote
Old 07-07-2022, 08:26 PM   #2
beanious
Re: Dirt Every Day Episode 132 (K5 Blazer Rescue)
Your thoughts???
Old 07-07-2022, 08:46 PM   #3
Grumpy old man
Grumpy old man's Avatar
A small block chevy will run with 10 year old gas that smells like turpentine , 5 pounds of oil pressure , the timing way off and it will still run, bad but it will run , They probably spent most of the time looking for the OBD port to plug in their anal yzer .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 07-07-2022, 08:47 PM   #4
beanious
The results of their fix'n mishaps...
Old 07-07-2022, 09:06 PM   #5
beanious
Grumpy_Old_Man, you're totally on point. A SBC will run with everything off and even old gas! Heck they'll run on 4 cylinders, barely... I was totally bummed that they ended the episode without it even running or driving.
