Old 07-13-2022, 03:47 PM   #1
schovil69
Brake Booster Check Valve Grommet
Well...Here I am yet again, at my wits end trying to find the proper grommet for the brake booster check valve grommet. Try and try as I might, I cannot seem to get people selling these things to give me the diameter that actually matters in determining if the thing will fit the hole. The portion of rubber that sits outside the hole, either inside or outside the booster itself, is completely irrelevant. Rant over.
Speedway Motors Part Number: 92618599
schovil69 is offline   Reply With Quote
Old 07-13-2022, 07:11 PM   #2
mr.mud1
mr.mud1's Avatar
Re: Brake Booster Check Valve Grommet
hi,i pulled the grommet out of my 72 truck to make you a couple measurements.hope this helps.holler if you need anymore pictures or measurements.take care.Greg
mr.mud1 is offline   Reply With Quote
Old 07-13-2022, 07:26 PM   #3
kwmech
If I'm not mistaken...I've seen those at my local NAPA store in the HELP section along with a new check valve. They also carry the vapor filter used on the newer trucks
Old 07-14-2022, 12:12 PM   #4
schovil69
Thanks, Greg! I'm impressed that you would go to that trouble, much appreciated.
Now we just need to get the industry providing those measurements when selling the grommets. Some do and some do not. The Speedway Motors part number I posted does have those measurements yet other grommets on their website do not. I'm blown away that the overall outside diameter is what is most often used to describe these things.
Old 07-14-2022, 01:23 PM   #5
LNP
The Dorman 80189 comes with the new check valve and two grommets of different sizes. Dorman 80191 is just the two grommets. Below is a link to Online Tube where they sell a 64-78 all models check valve and grommet. If you check the Dorman site it has grommet outside diameter listed
https://www.inlinetube.com/products/...yABEgILavD_BwE
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 07-14-2022, 05:09 PM   #6
mr.mud1
mr.mud1's Avatar
not a big deal,no trouble at all.
Old 07-15-2022, 10:33 AM   #7
schovil69
I did pick up that Dorman check valve that came with two grommets. One of the grommets was too small and the other too large.
Old 07-15-2022, 11:28 AM   #8
LNP
Wow no kidding, sorry bout that. Have you had any luck with any others?
My trucks not factory power brakes. I have a aftermarket conversion on mine not sure if the measurements of mine would help. What year is your truck? I will still see if I can come accross any more
Harley
