Old 07-14-2022, 11:14 AM   #1
mike1971c10
mike1971c10's Avatar
manual throttle cable
My truck came with the manual throttle cable, but the truck has been Frankenstein since then. I would like to install one now that I bought from a board member some time ago. I still have the pedal arrangement but don't know where this bracket, that's on the cable, goes. Can someone take a picture under their dash for me?
mike
my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522167 vietnam vet 67-68
mike1971c10 is offline   Reply With Quote
Old 07-14-2022, 12:07 PM   #2
LNP
Re: manual throttle cable
mike
I stripped mine down to just what I needed for the accelerator pedal/cable.
I made a plate to bolt to the truck where the stock mechanical pedal/linkage went. I put three studs on it for the new assembly to bolt to. I threaded the holes for the studs then welded them on the backside so they will never come loose.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 07-14-2022, 12:13 PM   #3
LNP
I didnt have both sides of the pedal mount like it looks you do so I made the back piece for mine out of a piece of aluminum.
Harley
Old 07-14-2022, 01:41 PM   #4
mike1971c10
I think I answered my own question. I read a couple more threads on the manual throttle and I think this is the location. It located on the main structure below the steering column, that holds the brake pedal. I found a hole there that's scratched, like a bolt was there. thanks to DeadheadNM for digging it up a couple of years ago. Now all I have to do is figure out how it goes in also I found another picture from JT Trucks87 and he shows the position
Old 07-14-2022, 04:08 PM   #5
LNP
aaaahhhh I'm with ya now. You said manual throttle cable, and at first I thought what?? I seen the choke cable in the photo as well but never put two and two together. I went with throttle cable. You're wanting manual choke cable info. Thats my bad. I didn get it until I was lookin at the new photos you posted. lol I wouldnt have been able to help you with that I have electric choke. Sorry
Harley
