07-23-2022, 06:29 PM | #1 |
Rear brakes locking up before front - tips?
I had my truck in the shop a while back. They found the diaphragm had a leak, so it was replaced. They added a preset proportioning valve.
Since driving the truck, the rear brakes lock up well before the front. I've been told adjusting the rear drums within the drum won't help. My next step was going to buy a simple valve like this, to turn down the pressure doing to the rear brakes. Any other ideas??
1972 Cheyenne Super SWB PS, PB, Tach, A/C, Tilt. Drivetrain: Built 402BB, TCI Streetfighter 700R4, 2,500 stall, Eaton posi, 3.73. Suspension/Chassis: ECE 4.5/6.5 drop, CPP nitrogen shocks, CPP front and rear sway bar, CPP cross members. Exhaust: 3" exhaust with x-pipe, Spintech 3000 mufflers, Hooker ceramic coated headers. Best 1/4 mile time: TBD. |
07-23-2022, 07:10 PM | #2 |
Re: Rear brakes locking up before front - tips?
Are the front brakes even working. Can you take a pic of the master cylinder plumbing that is not 5 times the size of life size
07-23-2022, 07:22 PM | #3 |
Resize
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
07-23-2022, 09:33 PM | #4 |
Who Changed This?
I got tired of monkeying around with the kit I bought to convert my truck to front disc brakes and removed all the prop valve stuff. I put in that Wilwood valve, and adjusted it until the brakes "equalized". In my case, that valve is wide open, because I have a lot of weight on the rear tires, which only increases when I tow my 6k+ pound travel trailer. The jury is out on brake wear characteristics, since I have driven it maybe 7k miles since I did the conversion.
07-23-2022, 09:57 PM | #5 |
Post Whore
Do you have front drums or disks?
Long bed, short bed, Suburban, Longhorn? Under what circumstances do the rears lock up first? I would definitely bleed the fronts and do a thorough inspection of them before throwing parts at the truck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-23-2022, 11:18 PM | #6 |
Like HO455 says bleed the fronts including the M/C to make sure all the air is out.
07-24-2022, 12:29 AM | #7 |
My 1978 did that, it was a leaking axle shaft seal.
07-24-2022, 12:10 PM | #8 |
Good tips. I'll get the front in the air to see if the front brakes are even working. Then, bleed them.
It's a disk (front) drum (rear) setup. On hard braking, the rears have locked up. It seems like the fronts are doing nothing.
07-24-2022, 12:16 PM | #9 |
Possible that the valve is off center. Bleeding the front may bring it back unless it is stuck or there is another issue causing this
07-24-2022, 12:49 PM | #10 |
Pull the rubber boot off the Combination Valve. Have someone press on the brake pedal and watch the pin on the Metering valve to see if it moves out. If the front brake circuit is bled properly and the master is working properly, the pin will move outward.
The pin should be held in the OUT position when the brakes are being bled. They make a tool for that purpose. When the brakes are working properly, it takes only 50psi to push the Metering Valve pin OUT. When there is air in the lines. the air will compress before the fluid will reach the threshold pressure (~50psi) and open the valve so that the brakes can be bled. DON'T bleed the MC at this point. All that will do is provide the possibility of more air entering the lines.
'67 GMC 2500, 292, 4spd, AC |
07-24-2022, 12:50 PM | #11 |
I have the same problem on one of my trucks. 1968 and the front is converted from disc to drum... probably the same proportioning valve you picture.
I bought the Wilwood valve you picture, but have not installed it yet. I'm interested to see what you figure out. On my latest truck, I went with the Willwood proportioning valve that has the built in adjustment, also a 1968 converted to disc. It was super easy to get a good adjustment that didn't feel like the back end was going to come around... |
07-24-2022, 12:53 PM | #12 |
I'm going to throw this out there also...
https://www.youtube.com/watch?v=g63mP4HwVEQ Here's the CPP tool that I have. https://www.summitracing.com/parts/clp-pv-tool |
07-24-2022, 01:04 PM | #13 |
If your brakes check out, the way I see it you have a couple options.
1. Keep it as is and deal with it. 2. Get an original truck combo valve since its already setup for the truck. 3. Take your existing combo valve, remove/disable the proportioning guts, and install the Wilwood prop valve inline in its place. This keeps the metering valve and brake warning circuit intact. 4. Remove the existing combo valve altogether and only use the Wilwood prop valve. This gets rid of the metering valve and brake warning circuit tho.
72 C10 lwb fleetside -stock 350/350 combo Last edited by 68 P.O.S.; 07-25-2022 at 01:23 PM. |
