Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 07-25-2022, 11:13 PM   #1
chtr65
concrete sealers
Anyone have any suggestions or experience with any of the new concrete sealers on the market today? I have just had a new floor finished, and would like to apply a coating before we move forward with the rest of the framing. Thanks in Advance, Mike
chtr65 is offline   Reply With Quote
Old 07-25-2022, 11:17 PM   #2
62c30
Re: concrete sealers
I used Cure and Seal. I think there is a number after it but don"t remember it. It came in a blue I think 4 gallon can, used almost all of it on a 30x40 using a paint roller.
62c30 is offline   Reply With Quote
Old 08-04-2022, 08:33 PM   #3
lupo
New concrete should cure at least 30 days before a sealer is applied As far as sealers go single component moisture cured clear is very popular and very durable. Top coated with a two-part polyester, is your most durable and expensive floor system. Then comes the epoxy from the big box stores cheaper but not as durable
lupo is offline   Reply With Quote
Old 04-09-2023, 09:59 AM   #4
1972K20
1972K20's Avatar
I'm looking to seal concrete I had poured about a year ago.
Does anyone have anymore suggestions?
1972K20 is offline   Reply With Quote
Old 04-09-2023, 02:06 PM   #5
62c30
I'm not an expert but have been told by many people that do concrete that for a sealer to last there needs to be a vapor barrier under the concrete. If not it will flake off over time. I used a cure and seal on my garage floors just after they were poured. I would use an etch on cured concrete before using any product on it. Again I'm not an expert but have built several garages.
Old 04-09-2023, 03:50 PM   #6
72gmguy
72gmguy's Avatar
Just curious, is sealing concrete just to make it resistant to oil or is there another advantage? The concrete in my garage is insulated with a vapor barrier and was done about a year ago.
Jeremy
1969 Blazer 4x4 original cst
1971 Blazer partial 2wd convert
1972 Blazer 4x4 original cst
1970 Blazer 4x4 w/ 2 1/2in lift and 33in tires w/4 wheel camper
1970 4x4 suburban w/ 6in lift and 35in tires
1968 Corvette convertible
1970 Malibu convertible
1959 Brookwood wagon
1972 International Scout ii
72gmguy is offline   Reply With Quote
Old 04-09-2023, 04:14 PM   #7
62c30
Should help from staining it and help with sweeping
Old 04-09-2023, 04:35 PM   #8
kwmech
What kind of finished surface are you working with?
Old 05-24-2023, 08:21 PM   #9
4u2nv
Home Depot product called Behr concrete , masonry sealer
I've used it on the concrete around my swimming pool for years , doesn't peel , beads water , holds up decent even with the chlorine water that gets on it.
Doesn't break the bank either
Is there home Depot's in the USA ????
4u2nv is offline   Reply With Quote
Old 05-25-2023, 08:13 AM   #10
72gmguy
72gmguy's Avatar
EVERYWHERE! Lol
Jeremy
Old 06-22-2023, 08:58 PM   #11
PGSigns
PGSigns's Avatar
I used Euclid Diamond hard on my shop floor. It is a sealer and densifier. Been three years and happy with it. I do a lot of fabrication work and the surface is tough. Just added 500 square feet for a machine shop and used it this time also.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 08-13-2023, 02:50 PM   #12
Rust_never_sleeps
Rust_never_sleeps's Avatar
I was always told to prep(power wash) and apply bonding compound("concrete bonding adhesive") before laying any masonry products on existing concrete.
There might be stuff built into the coatings that provides the same function, but I think I'd put the extra steps in before I layed that stuff down.
Rust_never_sleeps is offline   Reply With Quote
