08-13-2022, 06:06 PM | #1 |
What gearing to go to.
I’m looking to change my gearing in my 72 K5. It currently has 3:08’s in it. I’m running 33x13.5r15 Nitto’s. Drive train is 400 sbc with TH350. Should I run 3:73 or 4:10’s. This is a street queen will never see the dirt. Mainly local driver. At some point I plan on LS swap it.
Posted via Mobile Device |
08-14-2022, 03:33 AM | #2 |
Re: What gearing to go to.
My 72 originally had 373's and 31 inch tires, stock TH350 trans. The rpm was a bit high for me. Around 2500+ if IIRC. If not planning on adding an OD trans with the swap I would go no more than the 373's. Would go 4.10's if planning an OD trans. My engine trans and axle swap with 37" tires and 5.13 gears should put me just over 2k on the highway. Right about where my 94 is. Comfortable at highway speeds with power still available. Great milage will never be attainable in these heavy old trucks with brick wall aero dynamics. All we can get is better performance with a bit more economy than 10 mpg.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
08-14-2022, 08:36 AM | #3 |
Carpe manana
I have 33” tires, th350, 350 sb, and 3.73s. Works well driving in and around town.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
08-14-2022, 04:51 PM | #4 |
3.73's with a TH350, or 4.10's with a 700R or 4L60.
08-14-2022, 08:58 PM | #5 |
08-15-2022, 10:46 PM | #6 |
My ‘72 Jimmy has 4.10 and an SM465 with 35” tires while my sons has 3.73 and TH350 with 35’s. Because of the converter, both trucks turn about the same rpm on the road. And the combo of 35’s, 3.73, and TH350 has the factory speedometer more accurate than anything else I own! Originally a 3.08 geared truck, I think 3.73 ideal for a TH350 equipped with 33-35” tire.
08-16-2022, 01:50 PM | #7 |
