08-16-2022, 09:11 PM | #1 |
brake booster swap
I am building a frakenstein truck. I mounted a 71 cab to a 03 frame, I have a 01 4 x 4 that i am parting out. I put the 01 stepside bed on the 03 frame. M y question is can i swap the 01 brake booster on to the 71 cab? I want to hook up the ABS and the 01 master wont mate up to the 71 booster, i would appreciate a little help, thanks.
08-17-2022, 05:21 PM | #2 | |
Re: brake booster swap
The new vs the old might also require a different pedal ratio so you'd need to research what the specs are for each & start from there.
08-18-2022, 11:40 AM | #3 |
Thanks, iwas looking at the bolt pattern, but i noticed it will be very close to my shift arm also. I didnt think about pedal ratio. T he bolt pattern for the master is the same, but the recess for the masters are different, the 01 is 5/16 " bigger than the 71. I am leaning towards having it turned down, it would resolve most issues.
08-18-2022, 01:52 PM | #4 |
Hydroboost. It's worth the effort.
08-18-2022, 03:05 PM | #5 |
It's all relevant to the application. Hydroboost is great for some (many?) apps.... Not so much on others.
08-18-2022, 05:46 PM | #6 | |
At the body shop.
My brother's hydro boost has proven to be a pita Manual or vaccum for me thanks
" That didnt make it any newer " " Dont antique the equipment " |
08-22-2022, 08:02 PM | #7 |
a friend of min e suggested that
