Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Trucks For Sale
Old 10-03-2022, 05:42 PM   #1
69Tom
69Tom's Avatar
1970 C10 Short Bed Stepside Project
I have a bunch of house repairs going on and need the money, so I have to sell this project before I can get it done. I finished my C20 (avatar pic), so I guess it's a bit redundant at the moment anyhow.
Specs: 1970 Chevrolet C10, original South Carolina truck. Original stepside, short bed. Original black paint. The pic I'm posting is how it looked when I bought it. Damage during shipping, along with a ton of rust in the fenders, bed, doors...well, everywhere, led me to blow it a part.
I started repairs on the cab and then unearthed the roof had been replaced at some point, and poorly at that. Along with pinholes from rust in the cowl area, I decided to just get another cab (which is also pictured). Cab is from farm country in CA. Mostly rust free (I've determined there's rust in these cabs no matter from where you get them, it's just in degrees).
I have most of the work done on the frame and suspension. Rear end was rebuilt with a stock posi unit in good shape, with 3.07 gears. For the suspension and brakes, it's an ECE 2/4 drop kit, and front disc bake conversion kit.
I have multiples of several things, due to buying the two trucks/cabs. So there's 4 doors, 2 hoods (one is good, other has damage), 2 cowls, 2 bench seats, etc.
Engine I have for it is a 1972 402 that was complete. I broke it down and took it to the machine shop. Everything has been cleaned, fluxed for cracks, heads have new valve seats, etc., block has been honed and bored, at I believe .030 over (I'll have to double check the paperwork - I have everything), new pistons, cam kit, timing chain, replaced the crank, etc. I have well over $3K on the parts and machine shop work on this. Plus I paid 1200 for the engine to begin with.
Brand new Mar-K stepside bed, including new bed wood. (only need new fender wells).
I have the PPG Deltron single stage black paint for this.
Below, I'll provide a list of parts I have for the truck. I actually think I have more than I'm listing. There's so much stuff I've bound to miss listing a thing or two. Listed below, I've added up receipts and have over $25,000.00 in parts. A cool thing I have is an original GM parts grille guard that's been powder coated in white and looks great. Also have a Custom C10 original material seat cover from USA Inc.
I'm aware I'm losing money selling it this way, but I need it sooner than later. I have this hopefully priced to sell. I'm willing to hear offers as long as they're not insulting. It's a black short bed. Clear title. Located in Phoenix, AZ. SOLD
Parts list Everything listed is new, NOS, or rebuilt.
Cab Mounts (classicparts) 69.90
Rear brake upgrade kit & rear mount steel gas tank (ECE): 997.47
American Autowire Wiring Kit: 475.00
Dash Pad: 79.97
Front to Rear Fuel Line $56.70
Bed floor mounting bolts $11.24
Grille Shell $499.00
Headlight Bezels $41.99
Tailgate chain covers $14.88
Drive shaft powdercoat $75.00
Rims blast and coat $276
Control arms & cross member blast and coat 148.62
Torque converter $116.99
Diff cover bolts $23.65
Exhaust system $266.99
Trail arms $459.75
New tires $624.85
Trail arms powder 53.08
ECE drop kit & disc brake conversion $1525.00
Bolts misc (LMC) 95.00
Bed steps $172.62
Engine mounts, trans mount, steering rag joint coupler (classicparts) 95.24
Driveshaft rebuild $159.74
Power steering box 67.00
Power steering box rebuild 14:1 ratio $333.77
Trail arm bushings $44.05
Diff cover bolts $28.68
Magnaflux and clean block and heads $234.00
Engine gasket kit 68.99
Cam, lifter kit, timing chain,valve springs $438.96
BB crankshaft pulley 72.00
BB alt bracket set 72.00
Dual Fan shroud, 2 electric fan, fan wiring kit 315.00
PPG single stage black paint, reducer, hardener for full truck 633.86
Center air vent 21.17
Tracking arm stud kit 19.95
Fuel filler polished – keyed 59.95
Fuel pump 34.95
Front fender seal set 12.95
Tracking arm bushing 12.95
Fuel pump pushrod 9.95hood shock insulator kit 11.95
Rear control arm bumper 19.90
Rear shock mounts 38.00
Axle bearings 10.00
Front end rebuild parts 367.80
New lug nuts 24.00
NOS GM ignition lock and key set 27.50
NOS GM C10 fender emblems 140.00
Hood bow tie emblem 49.99
Side marker lamps with gasket 22.00
OEM style steering wheel 260.00
Horn cap 25.00
Steering to colum dash seal 7.95
Sill plates 44.95
Arm rests 41.90
Door handle & window crank set 18.95
Gas pedal and trim set 29.00
Windshield seal 36.95
Rear window seal 34.95
HEI Distributor 75.00
NOS GM trailing arm bushings 55.16
Fender to radiator support brackets 18.00
Big block oil pressure line $17.00
Key parts front & rear bumpers 217.80
Door panels 174.73
Tilt column, rebuilt 469.00
Moog control arm shaft kit 30.79
ACC blue carpet 155.00
ECE hidden hitch and license plate holder 185.00
Ring and pinion installation kit 214.53
NOS GM Parking lights with lenses 128.75
NOS GM door lock knobs 25.03
GM ring and pinion set 3.08 75.00
Window regulator handle 24.98
NOS GM door weatherstip & windshield seal 339.90
Vintage Air A/C complete kit 1375.00
Cab mount kit 69.90
Parking brake cable set 169.00
Proportioning valve rear 85.00
Brake hose set 53.00
Inline power disc conversion brake line set 189.00
Fuel line clip set 8.00
Brake line clip set 28.25
Big block power steering hoses 98.00
NOS GM dome light lens 22.00
(2) NOS Reverse Light assembly with lens 155.00
NOS Delco Ignition switch 48.00
(2) NOS GM tail light housing 90.00
Auto trans brake pedal assembly 50.00
402 Kickdown switch 50.00
TH400 vacuum line 35.00
NOS GM power brake booster 289.99
Dash vents (Classic Industries) 66.35
A/C controller 39.00
Big block pump, brackets, and pulleys 286.00
Big block power steering additional parts 100.00
TH400 short bed drive shaft 145.00
BB engine mounts 175.00
TH400 transmission 250.00
1972 402 motor 1380.00
Cold case radiator 296.99
Mar-K stepsite bed sides, front panel, tail gate, bolt kit 1437.00
Mar-K bed wood, cross sills, mounting pads, bed strips, heat shield 739.40
15x6 6 bolt wheels 400.00
Gauge cluster restoration 225.00
NOS GM door jamb light switches 33.75
GM fenders and wheel wells, core support 416.00
Shoulder seat belts 270.00
Cars Inc NOS Custom C10 seat cover 454.00
Voltmeter gauge/conversion 115.00
Engine: 2109.40
- Magnaflux
- Bored .030
- Valve job on heads
- New crank
- Grind crank
- Valve seats
- Cam lifters and timing
- Resurface
Carb & rebuild 375.00
Windshield 165.00
Rear window 75.00
GM Parts Grille Guard 550.00
Call me if you have any questions or to discuss anything. PM me for my number.
69Tom is offline   Reply With Quote
Old 10-03-2022, 05:43 PM   #2
69Tom
69Tom's Avatar
Re: 1970 C10 Short Bed Stepside Project
Pics as it sits now.
Old 10-03-2022, 05:44 PM   #3
69Tom
69Tom's Avatar
More pics and pics of additional cab.
Old 10-03-2022, 05:46 PM   #4
69Tom
69Tom's Avatar
More pics, including hood.
Old 10-03-2022, 05:48 PM   #5
69Tom
69Tom's Avatar
Pics of frame restoration, brakes, suspension
Old 10-03-2022, 05:49 PM   #6
69Tom
69Tom's Avatar
More pics of frame.
Old 10-09-2022, 09:12 AM   #7
rob32472
PM sent
rob32472 is offline   Reply With Quote
