10-11-2022, 10:02 AM | #1 |
60-62 Rolling Short Frame
As pit free a frame as you will find. The front cab mounts (for 63-66 cab) have been welded on, and some repair has been done on the lower bumper mount (still fits 60-62 bumper). Has a maybe later truck 12 bolt (cast 3817769). Rolling on 2008ish wheels, center holes cut to fit.
Start with a solid frame, Porterbuilt makes a ton of suspension stuff for these. $850 for the rolling frame I also have the bed sides (pictured), bed front panel, tailgate bed floor, radiator, fenders and a few more parts that could go along. Tom |
10-11-2022, 10:03 PM | #2 |
Re: 60-62 Rolling Short Frame
I’m interested but leaving on vacation for two weeks. Will check back. Interested in bed and frame
Thanks Joe |
10-12-2022, 10:49 AM | #3 |
What’s the difference between the 60-62 cab mounts and 63 up?
10-12-2022, 09:28 PM | #4 |
60-62 are further from the frame rail than 63-66
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-13-2022, 10:04 AM | #5 |
This frame had a 63-66 cab mounted on it. I'm assuming the original cab mounts were to wide, so later mounts were welded in place. If a 60-62 cab goes back on this frame, it'll probably need to have these mounts removed and early mounts installed.
10-24-2022, 12:12 PM | #6 |
Just the frame is remaining.
