11-19-2022, 07:22 PM | #1 |
LS Swap and NNS/Brake Light Switch
I recently completed an LS swap and purchased a new Netural Safety Switch/Backup Light Switch. The problem is that Switch is made for a turbo350 transmission and i have a 460le. any ideas on how to get the Switch to work properly so that i have reverse lights?
I also have the dakota digital guages with the GSS-3000 unit and the relay for the NSS of needed, but i don't know how to hook up the relay or if it would be a better solution. Thanks |
11-19-2022, 09:10 PM | #2 |
Re: LS Swap and NNS/Brake Light Switch
I found this on dakota digitals website and im wondering if i just disconnect the factory NSS and wired the relay to the factory harness would that be best?
11-19-2022, 10:09 PM | #3 |
What is your current stock setup? NSS on the steering column?
11-19-2022, 10:58 PM | #4 | |
I would use the factory NSS on the steering column since it already does the safe starts in in park/neutral and turns your reverse lights on. So you don't need the relay or extra wiring.
https://www.dakotadigital.com/pdf/GSS-3000.pdf |
11-19-2022, 11:52 PM | #5 | |
I have tried to adjust the switch, but i can only adjust as follows: park-starts reverse-no start neutral-no start overdrive-starts drive-starts 2nd-starts 1st-starts All while the reverse lights never come on. I have jumped the 2 green wires on the reverse switch and the reverse lights light up, so i know they work. |
11-19-2022, 11:59 PM | #6 |
11-20-2022, 12:02 AM | #7 |
Let me see if I understand this correctly;
Both the thm350 and the 700R4/4L60s use the same PRND. PRND21 PRND321 The first gear is just further down on the column. This means they both should be able to activate the NSS correctly. I am just guessing the ratio between the column and the shifter on the transmission has changed and is not the same ratio as the factory designed it. This could make the switch not index correctly. Just a guess. Cheers |
11-20-2022, 12:59 AM | #8 |
A better way than using the NSS on the column is to use the NSS and BU light off of the 4L60. I found that I could not get effective BU lights and NSS together using the column mounted piece.
For some reason I can't attach pics right now, but you can download the Painless wire harness instructions for PN 10204 See page 99 of the instructions (page 109 of the pdf). https://www.painlessperformance.com/Manuals/10204.pdf |
11-20-2022, 11:18 AM | #9 | |
11-20-2022, 11:28 AM | #10 | |
Any idea how to adjust so all 3 are in sync? |
11-20-2022, 11:50 AM | #11 |
I am going to assume you are using an aftermarket shift indicator on the column with the overdrive on it. If so, give it up, those are not correct at all and won't line up with the stock NSS on the column. I've tried, they just aren't right. But since you have DD gauges, I would just use the DD box for the shift indicator and neutral safety switch. It will be more wiring, but it is infinitely adjustable so you know it will work. I have one in my car and it was pretty easy to set up.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
11-20-2022, 12:06 PM | #12 | |
So should i just unplug the factory NSS and wire up some pigtails to plug the relay into the factory harness? |
11-20-2022, 12:46 PM | #13 |
A couple of great ideas to solve your issues. I thought about the transmission switch but figured it was only good for computer controls amperage. Using a relay should make this possible. I also made the assumption the spacing on the column indicator was the same as stock. Why I like this forum.
Cheers. |
11-20-2022, 04:10 PM | #14 | |
I am noticing i have reverse lights in drive...hahaha. i guess I'll hookup the relay and use pigtails to the factory harness. |
11-21-2022, 02:55 PM | #15 |
Not necessarily an option for the op if he wants to retain the column shift but I chose to go with an Art Carr/Winters floor shifter because it has the nss and reverse switches (#177-1 and 1089-29 nss and reverse switch). An added bonus is that it is cable activated so I had some leeway in where I mounted it on the hump.
11-21-2022, 08:15 PM | #16 | |
11-27-2022, 11:31 AM | #17 |
I am going by memory at this point but here goes. I had the same problem with trying to use the column switch with no success when I went with a 460 trans, found out there are 2 different style 460 trans, one uses a switch that mounts to the trans shifter shaft the other does not. My trans came out of a 2002 trans am and it did not use this type of switch BUT the only difference is the length of the shifter shaft between the 2-style trans. So, I bought the longer gm shaft and replaced it and then I could use the GM switch. If you search my old threads all this info is in there. It is easy to change the shaft. The wiring was easy and now I have back up lights and neutral safety lock out.
11-27-2022, 11:48 AM | #18 |
Interesting as I had the switch, located on the side of my 4L60E transmission, but didn't like the shaft sticking out so far so I converted it to the short shaft/no switch. I am having issues getting the indicator and the neutral safety to both work correctly together. Currently I am considering returning to the stock indicator. I have converted several without changing the indicator, to match the 4 speed automatic, and had no issues lining things up. Just manual low is off the indicator on the right. No big deal as I never shift my truck manually. Just one more thing I wish I had known before the build. My 4L60E came out of a 1999 truck.
Cheers |
11-27-2022, 07:28 PM | #19 | |
Yea, i got the reverse lights and NSS to work with the stock column shift indicator, the problem i am having now is i cant get the gears to lineup properly. So my NSS only works until drive then it will start after that. But at least it wont start in reverse... |
