![]() Join Date: Jun 2002
How rare ???????????
How rare is a gauge cluster with a factory tach ??? 1981=1987
Re: How rare ???????????
If you have one I would hold on to it. They are gettng very difficult to find.
I've look at I don't know how many at junk yards and in the wild and have only seen 2-3.
Scott 1982 GMC Sierra |
I used to pull cluster parts from local junkyards to resell on eBay and elsewhere. Out of 70-100 clusters over maybe 3 years I probably got 10 with tachs?
The real finds are the c50/c60 tachs that have the fuel gauge and tach integrated into one unit.
1988 "Crane Truck" C30 - 350, SM465, with a 15' knuckle crane - thread 1986 M1009 - 6.2 Diesel, SM465, 2 speed aux trans, NP205 - thread 1979 Corvette - 350 T5 1977 Jimmy - 350, TH400, NP203 1982 Blazer - 350, 700R4, NP208 - Totalled, now a parts truck ![]() Scratch built 16' flatbed trailer - thread |
Is the main wiring harness plug and play for the c50/c60 guage swaps?
Yes, the power and coil wire are. But you need the 1). printed circuit board (E-bay) get the right one there one guy selling re-pops. not sure how many he has. 2). Tach cluster backing plate (LMC) for the year options you're working on.
Now the Tach with small gas gauge at needs to modify to the plastic you can't have warning light at the bottom of the Tach. for the gas gauge wire terrals.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. Last edited by Pontiac1976; 12-03-2022 at 12:46 AM. |
#6 | |
But you can remove the pins from the connector on the truck harness and re-pin it to match whatever cluster you have. It's just a matter of figuring out what wires go where.
![]() Join Date: Feb 2000
Here is some good info on factory tach clusters.
http://www.73-87.com/7387garage/inte...achometers.htm
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
