12-07-2022, 09:47 AM | #1 |
Lower control arm mounting parts
Good morning
Please see the photos. Looking to find out where I can buy these lower control arm mounts. They are threaded at both ends and have weld on washers. Any help would be appreciated. |
12-09-2022, 05:29 PM | #2 |
Re: Lower control arm mounting parts
Are you seeking application specific items or making your own arms?
If application specific (like posted in the images), I'd start my search w/the various aftermarket supporting manufacturers for the specific make (in the case of those images, anyone supplying aftermarket parts & stuff for Vettes). If you're building from scratch, that will take a little more effort. You might have to source the materials from one manufacturer/supplier & have things machined to fit your specific needs.
