Old 12-15-2022, 03:32 PM   #1
KyleSeal
KyleSeal's Avatar
Electrical Issues!
Ive got a 78 GMC C25 Im working on getting some bugs worked out of. So here are my issues;
The turn signals hyper flash, and the bulbs are standard halogen bulbs. The left side will work, hyper flashing, and when the right side turn signal is put on, sometimes all four flash, sometimes not. The turn signal lever does not seem to effect it, it is a new part.
This is a customer's vehicle, from what he says it seems that this issue was present before rebuild the column.
Additionally, the gauge cluster does not light up when the headlight switch is pulled. He says the circuit board is new, and headlight switch is new too.
Any ideas?
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 12-15-2022, 06:52 PM   #2
TKCR
TKCR's Avatar
Re: Electrical Issues!
Sounds like a grounding issue. That’s usually the first and easiest to check. From there, check for an open/bare wire somewhere within the light harness.
Old 12-16-2022, 12:49 AM   #3
Dead Parrot
Halogen? For turn signal bulbs?
Instrument cluster often shares a fuse with the running lights. But not the turn/brake lights. Since you have issues with the turn lights, possible that is also causing issues with the dash lights.
Dead Parrot is offline   Reply With Quote
Old 12-16-2022, 09:38 AM   #4
KyleSeal
KyleSeal's Avatar
So far I have determined the headlight switch is the culprit for the dash lights (swapped with a good one from my 67), still working on the turn signals. What I mean by halogen is just non-LED. Not sure of the correct term.
Old 12-16-2022, 11:17 AM   #5
TKCR
TKCR's Avatar
Usually if your getting the hyper flash with the blinker bulbs, one of the bulbs is bad. If you swap out all the bulbs and your still getting the hyper flash, then on of the connectors for the lights is bad.
I had that on my truck when I first got it. I changed out all the bulbs, but I ended up changing out the connections for the marker lights in the grille, and that fixed it. Someone had poorly spliced them in, plus the connectors themselves just looked bad. Like they had gotten pretty hot at one time or another.
Old 12-16-2022, 11:58 AM   #6
KyleSeal
KyleSeal's Avatar
I will check and post my results. Thank you!
Old 12-16-2022, 12:12 PM   #7
TKCR
TKCR's Avatar
Your welcome, and good luck. Electric issues can be a pain chasing down. I know a little about chasing down issues. I worked in the repair dept at an auto factory for years. Bad grounds, cut or pinched wires were the bulk of the causes.
Old 12-16-2022, 01:56 PM   #8
Dead Parrot
Good find on the headlight switch. I am a big fan of 'known good parts' as a troubleshooting technique.
It was a lot simpler before halogen and LED muddled the terminology waters. As long as you had the proper number bulb, it just worked. I was worried that your customer had tried to fit halogen(normally pre-LED headlight type bulbs) in the turn signal spots as some kind of super bright custom job. That could cause all sorts of issues with standard flasher cans.
Does the emergency flasher switch make all four corners flash? I use that as a quick check for the turn bulb filaments and connections.
Old 12-17-2022, 07:13 PM   #9
KyleSeal
KyleSeal's Avatar
Yes, the emergency light makes all the proper spots flash, honestly Im curious if I am having an issue with one of the flashers on the fuse block. SOMETIMES when starting a turn signal, or 4-ways, they will blink the appropriate for 1.5 flashes, then go fast.
Old 12-17-2022, 07:17 PM   #10
KyleSeal
KyleSeal's Avatar
Update - so as far as dash lights go, the headlight switch was the culprit.
But onto the turn signals. I have found numerous poor ground spots and connections, and have since replaced with proper fittings and weather tight shrink wrap and such.
I have found a wiring diagram for the rear harness, and followed. Found that all six bulbs shared one ground and it should be one ground per side, so I did so, and the harness photo indicates the rear harness should have a crossover ground (tying both L & R together, still grounding once on each side) and I have found some solder spots that look OK, not thinking theyre the culprit. Still flashing fast. Attached is a pic of the harness Im following.
Old 12-17-2022, 07:38 PM   #11
KyleSeal
KyleSeal's Avatar
Success! I swapped the flasher in the fuse block for a known good one from my 84, and they flash as they should. BOTH of the flashers had gone bad, seemingly at the same time. My guess is when this gentleman did his column rebuild, he left everything hooked up and overloaded them or something. Or they both just gave up the ghost together.
Old 12-17-2022, 10:02 PM   #12
TKCR
TKCR's Avatar
Happy you fiqured it out, good job!
gmc, headlight, turn signal, wiring
