Old 12-20-2022, 10:10 PM   #1
biketopia
Leveling chassis
I'm getting ready to cut c notches and do other chassis work on a bare frame. What points do you all use for leveling, are these spots good to use for front to back &side to side?
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 12-22-2022, 11:03 AM   #2
biketopia
Re: Leveling chassis
Bump, anyone?
Old 12-22-2022, 02:51 PM   #3
Myself
Looks good. I like to use the bed mounts cause they're normally parallel to the frame.
Myself is offline   Reply With Quote
Old 12-22-2022, 10:51 PM   #4
PGSigns
PGSigns's Avatar
I always use the top of the frame. Check it in three places front, middle and back to ensure no twist.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 12-23-2022, 07:44 PM   #5
biketopia
Thanks guys, I'll do just that next week when I get back out in the garage.
Old 12-28-2022, 10:00 AM   #6
SCOTI
SCOTI's Avatar
Jimmy
Yep...
When I built my chassis, I checked @ the front (as far up front as possible); near the center (between front & rear cab mounts), & @ the end of the rails.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
