Old 01-12-2023, 10:43 AM   #1
rustycars63
exhaust manifold milling
1949 chevy truck 5.3 engine mustang 11 front end need clearance for exhaust manifolds . any used angle milling of exhaust manifold with good results . If so how much to cut or mill for good clearance?
rustycars63 is offline   Reply With Quote
Old 01-12-2023, 03:02 PM   #2
mongocanfly
Post Whore
mongocanfly's Avatar
Re: exhaust manifold milling
Milling could mean lots of things....what are you wanting to do?
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 01-12-2023, 04:03 PM   #3
rustycars63
I need clearance between exhaust manifold and frame of truck .
Old 01-12-2023, 05:51 PM   #4
LeesTruk
The exhaust manifolds from the 5.3/6.0 Trailblazer/Envoy/Rainier (don't fall for the TBSS hype, their all the same) will sit about an inch closer to the engine, than the stock truck manifolds
LeesTruk is offline   Reply With Quote
Old 01-13-2023, 11:28 AM   #5
A1971Blazer
A1971Blazer's Avatar
look at some used 2010 Camaro manifolds...they tuck in tighter to the engine and have a 2 bolt flange....
these are mine but this is on a '67
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 01-13-2023, 02:09 PM   #6
mongocanfly
Post Whore
I assume you mean you want to face off the manifold surface where it contacts the head????...not angle mill
Is that right..?... if so you could only do a minimal cut before youd get the flange to thin...and you wouldn't gain much that way anyhow... one of the options above might work..not sure how much clearance your looking for..
Also dont be afraid to do a frame notch for clearance..if you reinforce the area you cut out itll be fine
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 03-20-2023, 05:39 PM   #7
not2oldchevy
You want to angle mill the surface from O to 10 thousands from top 0 to bottom 10 thou. mine cleared perfect .
not2oldchevy is offline   Reply With Quote
Old 03-20-2023, 05:44 PM   #8
not2oldchevy
You want to angle mill the surface from O to 10 thousands from top 0 to bottom 10 thou. mine cleared perfect . 1953 3100
Old 03-23-2023, 09:33 AM   #9
rustycars63
What engine and what exhaust manifolds?
Old 03-25-2023, 02:27 PM   #10
not2oldchevy
5.3 with early c5 manifolds. works perfect plus they have the 02 sensor plugs
Old 03-26-2023, 10:28 AM   #11
rustycars63
