01-17-2023, 02:03 PM | #1 |
Lug Nut Torque
What's the proper torque setting for 7/16'' lug nuts on a '71 GMC Jimmy?
01-17-2023, 02:15 PM | #2 |
Re: Lug Nut Torque
I take 'em to 80.............1/2'' I take to 95......... and 9/16 I torque to 110
01-17-2023, 02:17 PM | #3 |
Re: Lug Nut Torque
70-90?
01-17-2023, 02:18 PM | #4 |
Re: Lug Nut Torque
there is always this
01-17-2023, 03:36 PM | #5 |
Re: Lug Nut Torque
Thanks Guys.
I consider it a K/10. GMC calls the Jimmy a K/1500. If the truck were a Chevy, it would be a K/5, but GMC never called them K/750s. Using KWMech's chart from the C+O/H Manual, I'll take them to 55 Ft/Lbs, then up to 75 Ft/Lbs. I'm running aluminum wheel spacers [1-1/4''] to accommodate some aluminum wheels off a '99 Suburban that have 0 backspacing. I was running on the freeway, about 60-65 MPH, when I heard a clunking noise that increased with speed. I pulled over. Thinking it may be the plastic fan shroud getting loose and hitting the fan, I used some bailing wire to secure that. Got back on the road and the clanking/vibration came back. Running the motor at idle when stopped, there was no noise. (I had to get a tow home. About 35 miles -- Hagerty is great.) So unless it's the transmission [SM465], transfer case [NP205], prop shafts or Universal joints, it could be the spacers wotking loose. They were installed in July, in AZ summer heat. Now it's cold. [Relatively]. Things were fine before the tire and wheel swap.
01-17-2023, 03:42 PM | #6 |
Re: Lug Nut Torque
With the spacers you should consider changing out the wheel studs for 1/2'' I do this conversion all the time. The 7/16'' studs are not really up to the task of larger wheels and tires especially with spacers.
01-17-2023, 04:02 PM | #7 |
Re: Lug Nut Torque
Interesting. For now I'm just going to tighten them up. Is 55/75 FP good for the spacers too?
01-17-2023, 04:05 PM | #8 |
Re: Lug Nut Torque
I'm running 235/75/16 Cooper Discoverer AS T3 tires.
01-17-2023, 04:45 PM | #9 |
Re: Lug Nut Torque
01-17-2023, 04:59 PM | #10 |
Re: Lug Nut Torque
01-17-2023, 06:01 PM | #11 |
Re: Lug Nut Torque
01-17-2023, 07:47 PM | #12 |
Re: Lug Nut Torque
01-18-2023, 08:14 AM | #13 |
Re: Lug Nut Torque
Chart is 1972, but the 1970 manual has same information, it is just written as paragraph instead of a chart.
01-18-2023, 11:29 AM | #14 |
Re: Lug Nut Torque
Great. Thanks.
