01-27-2023, 01:08 PM | #1 |
Master Cylinder & Booster Question
Looking to run a booster, 8 inch dual on my 67 disc drum conversion. I see a listing on ebay, booster + master + prop valve for around $200. It states the master is a 1 inch bore - does this sound OK for my application based on bore size and booster size? Running this booster for the clearance and also to flush mount on my firewall.
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
01-28-2023, 09:18 PM | #2 |
Re: Master Cylinder & Booster Question
Usually on power brakes with our trucks you would want the 1 1/8 master cylinder. Without the booster 1”.
It also appears we’re in the same neck of the woods |
01-29-2023, 08:48 AM | #3 |
Check in the Vendors section, CaptainFab has a booster/MC/PV for our trucks- other vendors as well. Imo, you can personalize your system so you get what you want, and be able to communicate before and after if you purchase a unit.
01-29-2023, 04:57 PM | #4 |
FWIW my PB/MC kit from CPP on my 72 (converted from manual to power front disc) uses a 1 1/8" bore MC
Tags |
booster, brakes, master |
