Old 02-16-2023, 10:18 PM   #1
hugger6933
Help I got a draw
On a 04 Avalanche. I have unhooked the neg cable and placed my test light one side on the cable the other to the neg term at the battery. I have unhooked one at a time every single fuse and relay and even the breaker. I also unhooked and unplugged the alt, yet still the test light shines. I rolled down the dimmer[heard that some GM had that as a problem] yet I still have a lit test lamp. Any ideas where to look I'm stumped. This truck has nothing extra added to the electric stuff it is all just a stock Av. Thanks in advance Jim
hugger6933 is offline   Reply With Quote
Old 02-17-2023, 12:26 AM   #2
EVRLET
EVRLET's Avatar
Re: Help I got a draw
When you say every fuse and relay, you did both fuse boxes?
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 02-20-2023, 06:11 PM   #3
AussieinNC
Moderator
AussieinNC's Avatar
Unplug the computer plug and check again....most computers need a small draw which would account for your light.
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 02-20-2023, 10:17 PM   #4
CarolinaHD
Moderator
CarolinaHD's Avatar
Hvac blower motor resistor
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 02-21-2023, 09:04 AM   #5
95 S_Trucker
95 S_Trucker's Avatar
I suggest using an amp meter or an amp setting on a DVOM. Test lights work great for older cars without modules in them. Not so great with these trucks that have modules that have time delays to turn off.
*If you have RPO CJ2, the HVAC module can take 4-5 hrs to turn off. That is normal
A draw should be 30 milliamps or less after all modules have shut down.
95 S_Trucker is offline   Reply With Quote
