Old 02-25-2023, 07:17 PM   #1
65truckowner
65truckowner's Avatar
Slow 66 build
I am planning on building another 66 c10. Plans are frame off and install a 230 3 speed. It is a custom cab. Going back the original color which is dark blue with a white top. It will take me a while but here are some pictures I started in the bed removing rust and welding in patch panels.IMG_4437 by Daniel Crymes, on FlickrIMG_6208 by Daniel Crymes, on FlickrIMG_6214 by Daniel Crymes, on FlickrIMG_6215 by Daniel Crymes, on FlickrIMG_6216 by Daniel Crymes, on FlickrIMG_6217 by Daniel Crymes, on FlickrIMG_6218 by Daniel Crymes, on Flickr
65truckowner is offline   Reply With Quote
Old 03-18-2023, 06:47 PM   #2
65truckowner
Re: Slow 66 build
I got one side of the front end tore down. I have the frame about clean on that side. I also installed the original cross member. Putting all new parts back.IMG_6263 by Daniel Crymes, on FlickrIMG_6264 by Daniel Crymes, on FlickrIMG_6265 by IMG_6266 by Daniel Crymes, on FlickrDaniel Crymes, on IMG_6267 by Daniel Crymes, on FlickrFlickr
Old 03-19-2023, 06:32 PM   #3
65truckowner
Re: Slow 66 build
I got the crack welded up and the frame painted on the drivers side. Also got the top a arm installed029 by 030 by Daniel Crymes, on Flickr/www.flickr.com/photos/169098912@N02/]Daniel Crymes[/url], on Flickr031 by Daniel Crymes, on Flickr
Old 03-19-2023, 10:43 PM   #4
cwcarpenter98
cwcarpenter98's Avatar
Re: Slow 66 build
Never a fun thing to see that crack.
I don't know if it helped at all, but I added a reinforcement plate to the inside of the frame that all three steering gear bolts go through. I also welded it to the frame. Hopefully mine won't crack again.
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 03-20-2023, 07:02 AM   #5
65truckowner
Re: Slow 66 build
Yes I welded a plate on the inside as well. Hopefully it will be solid now
Old 04-01-2023, 07:41 PM   #6
65truckowner
Re: Slow 66 build
A little more done IMG_6310 by Daniel Crymes, on FlickrIMG_6324 by Daniel Crymes, on Flickr
Old 04-29-2023, 06:08 PM   #7
65truckowner
Re: Slow 66 build
I have the complete frontend rebuilt now starting the rearIMG_6359 by Daniel Crymes, on FlickrIMG_6358 by Daniel Crymes, on Flickr
Old 04-30-2023, 09:43 AM   #8
Braunschweiger
Re: Slow 66 build
Good progress.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
