Old 03-15-2023, 07:57 PM   #1
D-n-Tyke
DBW Accelerator Pedal Options
Trying to figure out the best/cheapest way to get an working accelerator pedal installed in this swap. Using a 2006 6.0/4L80E. I kept the pedal assembly out of the donor but it was an adjustable style and don't want to deal with all that extra bracketry etc. I did see a guy that used a pedal assy out of a 1996-2000 C3500. Says bolts right up and then you just have to swap 2 wires in the interface cable.
Anyone use this pedal in their swap?
D-n-Tyke is offline   Reply With Quote
Old 03-15-2023, 09:13 PM   #2
Richard
Re: DBW Accelerator Pedal Options
The 05+ Corvette pedal looks identical to the 71-72 pedal, even accepts the SS trim. It is bolt in with Hart Rod's bracket. Have this setup in my 72. http://67-72chevytrucks.com/vboard/s...d.php?t=631165
A recent thread on the subject, just a few pages back https://67-72chevytrucks.com/vboard/...d.php?t=840601
Richard
Old 03-16-2023, 06:23 AM   #3
Joyridin
As Richard stated, I used a Corvette pedal. I made the bracket that bolts tot he firewall, but many people make them. I cut the pedal a bit shorter for myself, but I used all the chrome trim from a 72 pedal and it looks/works great.
Joyridin is offline   Reply With Quote
Old 03-16-2023, 07:35 AM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
My engine didn't come with the pedal or tac.. so I swapped it to dbc throttle.
The one I'm working on now has all the dbw stuff.. kinda wish I had swapped it to dbc
I think what Richard said will do the trick
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-16-2023, 08:57 AM   #5
Jason Banks
Jason Banks's Avatar
Not sure if it is the same on the 2006, but my 2003 adjustable pedal had a smaller range or motion than the non adjustable of the same year.
I originally got a replacement non adjustable and my pedal sat kind of high. In a quest for maximum leg room, I sliced, diced and welded to get the adjustable pedal as close to the floor as I could when fully depressed.
Jason Banks is offline   Reply With Quote
Old 03-16-2023, 12:56 PM   #6
bigmoe
bigmoe's Avatar
For some reason the difference between truck and car pedals is two wires have to be swapped positions. When I used a car pedal on my swap (08 truck 5.3 Vortec) I had to swap two wires in the D and F positions at the pedal plug. The WH/BK and the BN ones.
bigmoe is offline   Reply With Quote
Old 03-16-2023, 07:06 PM   #7
ls1nova71
ls1nova71's Avatar
A lot of these comments are not going to work on a GenIII engine. With a 2006, you are pretty much stuck with using a 2002-06 pedal. I have heard of people using the diesel pedal you posted a pic of, but others have had problems with it. Never personally tried one myself, so have no firsthand experience with it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-18-2023, 09:17 AM   #8
kev2809
low n' slo
kev2809's Avatar
I don't think I've seen the adjustable style. my 2002 pedal mounted to hart robs bracket fit like a champ
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 03-18-2023, 11:40 AM   #9
bigmoe
bigmoe's Avatar
This is what adjustable pedals look like. I think they came with well optioned vehicles. They have a cable driven gear box on them to adjust the height. I've heard of people removing the adjustable part and replacing it with a permanent link of some sort, once they figure correct height.
Old 03-19-2023, 12:41 PM   #10
D-n-Tyke
Yeah I heard you have to use the original TAC module from the 2006, the earlier pedal assembly along with the earlier wiring harness, with a couple wires swapped. Have the TAC pinout for the 2006 TAC module/ pedal assy, just need to find the pinout for the 2000 setup so I know I get the connecting harness pinned out correctly.
It is my understanding the the big difference between the 2 setups is that the earlier units use 3 potentiometers in the pedal while the later version only use 2. But from everything I read the first 2 that used are the same in both eras. So when using the earlier pedal with the later TAC module it just ignores the 3rd potentiometer.
Old 03-20-2023, 11:36 AM   #11
kev2809
low n' slo
kev2809's Avatar
ohhhh, then i have seen them, just never out of the truck!
OP, is there a reason you dont want to use the 2002-2006 pedal with the TAC box? seems like the easiest and cheapest option
-_--_--_ _________
Old 03-20-2023, 04:33 PM   #12
D-n-Tyke
If I go get a non-adjustable pedal (cause I don't want to have to slice and dice my adjustable) 2002-2006 pedal then I have either buy a mounting bracket or figure one out myself. If I have to buy a pedal anyways and I just buy the 2000 C3500 pedal it bolts right into the 69 factory mounting holes and I just have to swap two wires on the harness connector.
Old 03-20-2023, 05:49 PM   #13
bigmoe
bigmoe's Avatar
Here's a pic of the 94-2002 2500/3500 pedal
Old 03-20-2023, 07:06 PM   #14
D-n-Tyke
That is the one I am looking at. Have you successfully run this pedal in a swap?
Old 03-20-2023, 07:22 PM   #15
bigmoe
bigmoe's Avatar
No I looked for that picture out of curiosity. I used a car pedal that came with my Gen IV truck motor I got from a guy who collected everything for his swap and changed plans.
Old 04-07-2023, 01:44 PM   #16
Jason Banks
Here's a new video on the the pedal topic. This is the guy that mentioned in an earlier video that that adjustable pedals have shorter travel:
https://www.youtube.com/watch?v=_qO5Jjl6Py0
Old 04-09-2023, 10:06 AM   #17
Accelo
Accelo's Avatar
The first DBW Corvettes 1999-2001 (The first adapters in the GM line) require their own TAC module. It is expensive and impossible to find. Be sure to avoid that unit.
Accelo is offline   Reply With Quote
