Old 03-17-2023, 08:03 AM   #1
scott123
72 grill question
My 72 came with a 68 front clip when I bought it. I have changed front clip and will order a grill shell and insert this week (back to the 72).
I have a 69-70 grill from another project.
The outer grill supports that rivet to the grill shell....will the 69-70 rivet up the same as a 71-72 or do I have to buy new outer supports as well?
Thanks.
Scott
scott123 is offline   Reply With Quote
Old 03-17-2023, 10:36 AM   #2
blazerowner71
Active Member
Re: 72 grill question
If you look at LMC catalog the part numbers for the outer supports are the same but the center one has a different part number
blazerowner71 is offline   Reply With Quote
Old 03-17-2023, 01:33 PM   #3
scott123
Thanks.
I thought I read it with different numbers on the outers.
I will double check.
Scott
