03-27-2023, 11:41 PM | #1 |
Engine placement
Do you have to move the engine forward so the valve cover doesnt hit the firewall?
1967 Nova SS LS9 800HP 1965 Malibu SS Convertible F/S 1965 Chevelle 2-Door Wagon F/S 1972 K5 Blazer 5.3 |
03-28-2023, 02:07 AM | #2 |
Re: Engine placement
The motor mounts where they bolt to the frame can be moved to the next set of holes so the valve cover fits. You have a 6 cylinder? Only mentioned a valve cover singular?
03-28-2023, 07:44 AM | #3 |
I have an LT engine, not an LS, but the dimensions are about the same. I had to move it forward 1.75", which was the next set of holes on the adapter plates. This gave me about 1" of room behind the valve covers. It worked well with the 6l trans as the tailshaft was almost in exactly the same place as the TH400 and I had to shorten the driveshaft 3/4".
03-28-2023, 09:53 AM | #4 |
Im sorry I should have said I have a LS 5.3. I thought I read some people made it work and some havent. I have a dirty Dingo cross-member.
03-29-2023, 02:23 PM | #5 |
'65 C10 with LS1 and I had to move my mounts to the furthest forward set of holes to allow for firewall clearance.
03-30-2023, 03:28 PM | #6 |
65 C10 with 5.3 Gen IV. I have the adapter plates with 4 positions and I'm in the 3rd position away from the firewall.
