Drop crossmember and carrier bearing
I have searched the site for an answer but have yet to find one. I am installing a drop crossmember as I am lowering my truck by 4/6 and I am not sure what to do about hanging the carrier bearing. Anyone have a solution? Thanks in advance.
“Somebody has to do something, and it's just incredibly pathetic that it has to be us.” Jerry Garcia |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Drop crossmember and carrier bearing
You dont need to change the cross member or carrier bearing when lowering the truck! The drive line stays intact and inline with the motor mounts, the trans crossmember and mount, the carrier bearing all remain inline as per the factory. Only the rear axle raises to reduce the pinion angle to carrier bearing angle. You start raising the drive line your going to cause all kinds of unnecessary u-joint problems! Shock relocators and an adjustable panhard bar are all that's required to lower the rear beyond 4" inches...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Post Whore
![]() Join Date: Feb 2016
What Ironangel said.
What model is your truck? Is it going to be a static drop? Some folks will drill out the rivets on the trailing arms mounts at the crossmember and flip them over. Do a site search for more information on that modification. Some folks have no carrier bearing problems with a 6 inch drop and others have bearing failures. When you lower the rear it forces the driveshafts forward. This may push the carrier bearing rubber too far and it then the bearing fails. After you have completed the lowering put the truck on jack stands so the suspension is at ride height. Then unbolt the carrier bearing mount from the crossmember. Once it is free hold it in place and check to see if the bolt holes still line up. If not then grind the mount so they do. This will move the mount back and the rubber donut is in a neutral position. (i.e. the rubber is not preloaded forward ) These steps are unnecessary if your drive shaft has the sliding yoke in the rear shaft as most 3/4 tons do.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Thanks Ironangel and HO455. Yes it is a static drop on a 69 C10. I have been going back and forth on this and your answers sealed the deal on not changing the crossmember. I will take this info and apply it when I get the rear half completed. Thanks again!!!!!
Post Whore
You're welcome. Take some time and post some pictures of the truck and the process. We all love looking at trucks.
Yes sir, I just posted an update on my psot "Scrappy's 69". This forumn is awesome and am delighted to be part of a group like this.
#7 | |
That's awesome, love the duo you have there. Unfortunately, a PO had heated the springs to drop it and they are collapsed mostly, bounces like a bronco over the least bump.
Surprised nobody asked since it's within your post info.... What 'drop crossmember' are you referencing?
The trailing arm crossmember where the carrier bearing attaches.
Gotcha. Never heard of the aftermarket T/A x-member replacements referred to as a 'drop crossmember'.
