Old 05-07-2023, 08:46 PM   #1
6600DURAMAX
6600DURAMAX's Avatar
LS3 Thermostat issues
Need a little help - have Blueprint Engines LS3 with the CVF front drive kit -
Originally installed a vintage air 186 degree (part number 707171) thermostat with a Summit - SUM-370998B swivel thermostat neck - this setup resulted in a slow drip from the bottom the the thermostat housing.
I talked to CVF as t I thought I might have the wrong setup - they said all their kits run LS1 stuff and gave me part number for Mr Gasket Housing - 2670 and the thermostat 6367 part number ( 160 degree which I actually like better anyhow )
When the Mr Gasket neck and thermostat arrive I did a better job of dry fitting it and it doesnt appear to fit?
You have to push ( or compress) the thermostat spring to get it to seat flush then it appears the gasket doesnt fit into the housing correctly ?
What am i doing wrong ?
1972 K5 Build - plans - LS3-6L80e-One Tons.....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 05-07-2023, 09:18 PM   #2
LS short box
Re: LS3 Thermostat issues
The stat on the left is for a LS1. The little notches near the rubber gaskets clip into the stock LS1 aluminum stat housing.
The stat on the right is for a LS3 ish engine. It does not clip into the thermostat housing.
The LS1 and the LS3 thermostat do not interchange. The LS3 thermostat is slightly larger in diameter compared to the LS1.
It really depends on your water pump. Is it a 2002 Camaro or a later model Camaro?
LS short box is offline   Reply With Quote
Old 05-07-2023, 10:45 PM   #3
6600DURAMAX
Both thermostats looks very close if not the same as far as gasket size ..... neither really fit in the housing on the engine .
Its a LS3 from Blueprint engines but has a CVF front drive kit
Old 05-07-2023, 11:10 PM   #4
mongocanfly
Post Whore
mongocanfly's Avatar
If its leaking around the housing, sand the mating surface to clean the finish off it.. mine was chrome aluminum..then use a good silicone sealer on it.. I swapped mine to a straight housing like you have..and it leaked before I even tried cranking the engine..tried to seal it several times before I did the above..no leaks now..
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 05-08-2023, 07:38 AM   #5
Joyridin
Around 2014, they changed the thermostat style very slightly. Most aftermarket housing show something like 2004-2018, but that isn't the case. I bought the older style and opened up the hole where the thermostat mounts by about .05". I have been running it for 7 years with the LS3 thermostat and no issues.
Joyridin is offline   Reply With Quote
Old 05-11-2023, 12:37 PM   #6
6600DURAMAX
Just to close this out - purchased a LS1 thermostat housing with a 160 degreee stat
Part # is LPE-L310045297
Bolts in - will fill with fluid tomorrow - If I don't update again All is good !!
Old 05-11-2023, 04:56 PM   #7
LS short box
Just a tip that has worked for me. Before you install the new stat I drill three 1/8" holes in the metal flange that hold the gasket. Seems to help getting first start air pockets out of the system.
Old 05-12-2023, 08:15 PM   #8
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
the thermostat you pictured is from 2 different pumps.
theirs 3 different length thermostats, LS thermostat is not universal... its specific to the pump.
good video:
https://www.youtube.com/watch?v=2apgFAuo4Dk
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
