Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-04-2023, 09:25 AM   #1
65truckowner
65truckowner's Avatar
best valve spring compressor
What do you guys use and which is the best and safest compressor for valve springs on v8s and straight 6s. I have a cheap one and it sometimes does not work very good at all.
65truckowner is offline   Reply With Quote
Old 06-04-2023, 05:14 PM   #2
RustyPile
RustyPile's Avatar
Re: best valve spring compressor
Heads installed or sitting on the bench??
RustyPile is offline   Reply With Quote
Old 06-04-2023, 08:40 PM   #3
65truckowner
They are on my work bench right now
Old 06-05-2023, 05:34 PM   #4
RustyPile
RustyPile's Avatar
For working on removed heads, I use this one:
https://www.ebay.com/itm/13458590958...243129c795d976
Old 06-05-2023, 07:47 PM   #5
65truckowner
Looks like a good one for sure
Old 06-08-2023, 09:55 AM   #6
biketopia
https://www.summitracing.com/parts/sum-906788
I use this one for head's off the engine type jobs.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 06-12-2023, 04:04 PM   #7
MJN
MJN's Avatar
I've got this one, Lisle 44300, made in USA, does the job, worked great on my 235 valves. https://www.lislecorp.com/specialty-...compressor-267
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
