06-05-2023, 03:58 PM | #1 |
Help with frame id
Can anyone please help id this frame number 72J165955
6 lug coil spring suspension front and rear. Drum brakes front and rear. Thanks |
06-05-2023, 04:46 PM | #2 |
Re: Help with frame id
Frame pics
06-05-2023, 09:00 PM | #3 |
67-70 frame
06-05-2023, 09:49 PM | #4 |
The holes in the core support mounting brackets look large to me, so maybe it can be narrowed down to 69-70. If the rear end is the wider variety, then it would be 70.
06-06-2023, 09:06 PM | #5 |
All about them K’s
The answer is in the partial vin stamp pictured… That frame is a ‘72 built in Janesville, number 65,955 to roll down the line in the model year, you can look at the build date project to determine approximate build month/day. Someone swapped the rear axle and front suspension at some point, likely to put its 5 lug stuff under an earlier truck.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
06-07-2023, 01:42 AM | #6 |
Thanks for your help
