06-05-2023, 04:48 PM | #1 |
Another Vintage Air Sure Fit Question
Anyone that has had their V/A Sure Fit system installed for a while now having any problem with it? Specifically, the hoses coming through the plate that attaches to the firewall? I'm concerned about rubbing or chaffing, even though there are grommets to hold the lines. Reading through the instructions and this caught my eye. Was hoping for some positive vibes on this. Ha ha
06-05-2023, 05:47 PM | #2 |
Re: Another Vintage Air Sure Fit Question
The metal portion on mine stick through the fire wall - the grommets are a bear to get in but I don't see any concerns
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years |
06-05-2023, 06:00 PM | #3 |
06-05-2023, 06:04 PM | #4 |
I have done 2 of them. I just poked the hoses through the firewall with grommets. I kept an eye on them & never saw any problem.
George |
06-05-2023, 07:16 PM | #5 |
Why not use the bulkhead for all four lines, then no worries. Takes more lines but gives peace of mind. -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
06-06-2023, 06:22 AM | #6 |
06-06-2023, 12:58 PM | #7 |
I talked to Vintage Air - will need a separate line kit if using bulkhead. Before I would go that route I would run the lines out the pass footwell- through the fender and out under the battery for the cleanest look.
Tail light filler was a pain in the ass ( per my body guy) but it turned out pretty slick - love the smooth bed line and not seeing the filler neck/cap. In hindsight my body guy could have built something cheaper he feels - the kit is pretty expensive.
06-06-2023, 01:34 PM | #8 | |
Sorry that was a PIA for you. That wasn't my intention when I sold it. I just knew it was more than I wanted to take on after seeing it. |
06-06-2023, 05:16 PM | #9 |
No issues what so ever - I love it !!!
06-06-2023, 05:21 PM | #10 |
I'll take some better pics of the AC lines this evening - I was nervous as **** drilling a big hole in the firewall ....... - Ideally I would have drilled holes when it was in primer.
I'd highly consider the fenderwell route if you want a super clean look
06-06-2023, 05:36 PM | #11 |
I don't understand bulkheads. Most A/C systems fail at a joint, not the hose or the components. Adding 8 o rings sounds like a bad idea. Just my humble opinion.
06-06-2023, 07:20 PM | #12 |
That is looking slick man! Coming together nice!
06-18-2023, 10:22 PM | #13 |
I just bought a Vintage Air kit from a person who decided to sell everything he just bought for his build.
It is a kit for a non-factory AC truck. (Mine is not a factory air truck) It came with the heater block off plate, that has the four holes in it, to pass the lines through. My question is, can I run the lines through the fresh air vent on the passenger side, and run them behind the fender for a clean look, or do I have to go through the heater box delete panel?
"If it ain't broken, fix it 'till it is!" |
06-20-2023, 12:52 PM | #14 |
Extended Power, I routed my lines that way. But used the EZ Clip lines and fittings. Also used VanNatta Fab’s trim plate. Just mocking up everything right now.
06-20-2023, 02:57 PM | #15 |
Is this what you have? These hoses were installed in 1998 except for the low side hose, which was replaced because of a leak at the fitting.
I have never liked having the hoses run into the passenger compartment, instead of running hard lines from the inside through the firewall, like Old Air has always done.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
06-21-2023, 01:20 AM | #16 | |
1970 GMC 2500 700R Trans RideTech 4 link rear suspension - Air Bagged on all four corners 350 SBC 300hp Weiand Supercharger FiTech EFI |
