06-12-2023, 09:17 AM | #1 |
Gear questions
I have a 69 with a 400 sbc and 3 speed with 3.73s. During the build I swapped in a new posi but kept the factory gears thinking everything would be fine. I know from the factory the different series diffs align with certain gear ratios but do they make aftermarket longer gears i something like a 3.08-3.27 for the series 4? I hate to buy another posi but my first gear is useless and I’m running 3500 rpm’s on the Highway.
06-12-2023, 10:39 AM | #2 |
Re: Gear questions
You can go the opposite way (higher ratio to lower ratio) with a special "thick" ring gear, but you can't go lower to higher without a carrier change.
The pinion gear diameter is much larger on a 3.07 than it is on a 3.73+, therefore the ring gear has to be further away initially. You could swap in an OD transmission and keep the "fun" gear.....but it would be more involved/expensive.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
