Intermittent blinker?
72
The left blinker just stays on. Right works fine....then left works...then sometimes the light just stays on. turn signal switch or?? or if either front or rear blinker bulb has a sketchy filament?? |
Re: Intermittent blinker?
The flasher unit has a set of points and a bi-metal strip in it.. As current flows through the flasher, the strip heats up and bends. The points open and current flow stops.. The bi-metal strip cools and bends back, closing the points and the cycle begins again.. If a bulb burns out or an otherwise open circuit occurs, the current flow isn't heavy enough to heat the strip, so the lights don't flash..
Check all the bulbs, paying close attention to the left side bulbs.. If they are all good, your flasher unit is probably beginning to fail, replace it. |
Just dealt with a similar situation..my right front would intermittently work. Sometimes it would signal outside and on the dash and other times nothing but the left side always flashed.
I checked and added frame grounds, nothing..ordered a flasher assembly and took my column apart only to find that the contacts looked black and dirty. Before replacing, I cleaned the contacts with electrical cleaner, then put some die electric grease and all my signals work perfectly now. Before replacing parts, clean the contacts and see where you're at lol I guess I have a spare signal mechanism now..
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
#4 | |
My rear side bed markers do not blink, front fender side markers do. I assume that is right? I will try taping the front turn/marker lights to see if the filament is suspect and the rear bulb also. Ideally its either flaky bulb or flasher....I would rather not have to pull the wheel to replace turn signal switch....unless it comes to that |
Who Changed This?
![]() Join Date: Jan 2013
The rear marker lights are not supposed to blink, like the fronts do when using the turn signals.
tapping lights revealed taillight bulb was the culprit. Had another 1157 in my stash.
While poking around up front I saw the DS core support bolt lose. It would appear whoever put the body back on after paint used a FU carriage bolt....and stash bolt to the rescue. Always a good day when stash stuff resolves problems |
